SYSTEM INFORMATION | |
OS type and version | Ubuntu 20.04.4 LTS |
Webmin version | 1.994 |
Hi there,
I would like some insight into Webmin for two items:
- Does it restart every two or so hours?
- Any ideas what causes the error below?
As you may see from the log, there was a restart at 07:47 and then another at 09:57.
The one at 09:57 has some kind of panic and then both Webmin and Virtualmin stops working.
Any info will be appreciated.
[21/Jun/2022:07:47:34 +0200] Restarting
[21/Jun/2022:07:47:37 +0200] miniserv.pl started
[21/Jun/2022:07:47:37 +0200] IPv6 support enabled
[21/Jun/2022:07:47:37 +0200] Using MD5 module Digest::MD5
[21/Jun/2022:07:47:37 +0200] Using SHA512 module Crypt::SHA
[21/Jun/2022:07:47:37 +0200] PAM authentication enabled
[21/Jun/2022:09:57:35 +0200] Restarting
[21/Jun/2022:09:57:37 +0200] miniserv.pl started
[21/Jun/2022:09:57:37 +0200] IPv6 support enabled
[21/Jun/2022:09:57:37 +0200] Using MD5 module Digest::MD5
[21/Jun/2022:09:57:37 +0200] Using SHA512 module Crypt::SHA
[21/Jun/2022:09:57:37 +0200] PAM authentication enabled
**panic: fold_constants JMPENV_PUSH returned 2.**
