Description:Ubuntu 22.04.2 LTS
Release:22.04
Codename:jammy
ufw is disabled on all during the tests and thus doesn’t interfere with the results.
This is my configuration:
- NAT ISP Router with fixed public IP
It is the default gateway 192.168.1.1 giving dhcp to network 192.168.1.0/24
My hosts
LAN
ubserv known as:
- ns1.wingarmac.com lan ip 192.168.1.10
- ubserv.wingarmac.org wireguard server 10.5.5.1 on port 51515
- my master server
ubcynt known as:
- ns2.wingarmac.com lan ip 192.168.1.20
- ubcynt.wingarmac.org wireguard server 10.5.5.2 on port 8023
- my Cinnamon desktop environement
root@ubserv:/etc/apache2/sites-enabled# cat ubserv.wingarmac.org-le-ssl.conf | nc termbin.com 9999
https://termbin.com/mwld
root@ubserv:/etc/apache2/sites-enabled# cat /etc/webmin/miniserv.conf | nc termbin.com 9999
https://termbin.com/4b2c
root@ubserv:/etc/apache2/sites-enabled# cat /etc/webmin/config | nc termbin.com 9999
https://termbin.com/9f2t
VPN only
- mobile Samsung A32 known as:
VPN NETWORK
ubserv is:
- Apache server
- Bind ns1
- Wireguard peer 10.5.5.1 (https://ubserv.wingarmac.org/ is accessible but showing : ref1)
- Webmin host 1
- connected on router with fixed IP 192.168.1.10
ubcynt is:
- Bind ns2
- Webmin host 2
- Desktop interface
- Wireguard peer 10.5.5.2 (https://ubcynt.wingarmac.org/ letsencrypt ask is ok, but not showing as secured and not showing the page, see ref2)
mobile is:
- my Samsung A32 phone
- Wireguard peer 10.5.5.4
- use to access Webmin hosts with Chrome
- using data connection (distant host)
ref1:
ref2:
ERR_CONNECTION_REFUSED
Everything works fine excepts ones I’ve the letsencrypt active over the proxied webmin hosts.
Ubcynt has still the default settings in Webmin (minserv.conf and config are default)
Ubserv is also the Apache webserver and NS1 and running Webmin too, so I tried to make this one work over Apache first.
I do not use Virtualmin. I use only Webmin, since I use my own centralised page to list my webmin hosts on my apache main index page of www.wingarmac.org available only from my VPN (/var/www/html/index.html generated by script based on Wireguard handshakes to show present VPN hosts).
Can you help me find out way the page doesn’t load the Webmin scripts like it should. All cgi and proxy modules have been activated so that Apache can handle it, but it seems something goes wrong with webmin.
the first issue was the authentic theme, that showed the perl script instea dof the page. So I set the gray theme, and now this page shows up telling I’ve no access to the modules.
Can anyone help based on my configuration to make webmin avaible on my desktop for my VPN hosts running it using the host with domain name as url without specifying the webmin port (proxied by apache)?
root@ubserv:/etc/apache2/sites-enabled# certbot --apache
Which names would you like to activate HTTPS for?
We recommend selecting either all domains, or all domains in a VirtualHost/server block.
1: wingarmac.org
2: wingarmac.com
3: ubcynt.wingarmac.org
4: ubserv.wingarmac.org
5: www.wingarmac.com
6: www.wingarmac.org
Has been done for all the wingarmac.org domain successfully. (wingarmac.org is for VPN Webmin hosts - wingarmac.com will be for WAN services I’ll setup afterwards)
root@ubserv:/etc/apache2/sites-enabled# nslookup ubcynt.wingarmac.org
Server: 127.0.0.1
Address: 127.0.0.1#53
Address: 10.5.5.2
root@ubserv:/etc/apache2/sites-enabled# nslookup ubserv.wingarmac.org
Server: 127.0.0.1
Address: 10.5.5.1
root@ubserv:/etc/apache2/sites-enabled# nslookup wingarmac.org
Server: 127.0.0.1
Address: 10.5.5.1
I did also add my username to /etc/webmin/webmin.acl
