| SYSTEM INFORMATION | |
| OS type and version | Ubuntu 22.04.4 LTS (Jammy Jellyfish) |
| Webmin version | 2.111 |
| Virtualmin version | 7.20.2 Pro |
Hi Everyone,
I’ve been using Webmin and Virtualmin for few years, but I still consider myself a “Newbie”
A month ago I was forced to migrate from So You Start to a new bare metal server hosted by OVH.
The OS installation (OVH Image) went smoothly and without any issues.
But since then, almost every time an automatic kernel update takes place (leading into a required reboot), when I perform the reboot from the webmin interface, after the shutdown, the server does not reboot and a hardware reset has to be performed which needs a time-consuming intervention.
I don’t see anything wrong in syslog; only a blank once the shutdown has been completed.
Nothing in kern.log either.
Extensive offline hardware tests have been performed without any error being detected.
CPU temperatures are always well within limits.
Has anybody experienced a similar issue?
Any suggestions?
See below some system information:
System:
Kernel: 5.15.0-117-generic x86_64 bits: 64 compiler: gcc v: 11.4.0 Console: pty pts/1
Distro: Ubuntu 22.04.4 LTS (Jammy Jellyfish)
Machine:
Type: Server Mobo: ASRockRack model: E3C252D4U-2T/OVH serial:
UEFI: American Megatrends LLC. v: 4.03.OV01 date: 05/28/2024
CPU:
Info: 6-core model: Intel Xeon E-2386G bits: 64 type: MT MCP arch: Rocket Lake rev: 1 cache:
L1: 480 KiB L2: 3 MiB L3: 12 MiB
Speed (MHz): avg: 799 high: 800 min/max: 800/5100 cores: 1: 800 2: 800 3: 800 4: 799 5: 800
6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 84096
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
Device-1: ASPEED Graphics Family vendor: ASRock driver: N/A bus-ID: 05:00.0
Display: server: No display server data found. Headless machine? tty: 141x48
Message: GL data unavailable in console. Try -G --display
Audio:
Message: No device data found.
Network:
Device-1: Intel Ethernet X710 for 10GBASE-T vendor: ASRock driver: i40e v: kernel port: N/A
bus-ID: 03:00.0
IF: eno1 state: up speed: 1000 Mbps duplex: full mac:
Device-2: Intel Ethernet X710 for 10GBASE-T vendor: ASRock driver: i40e v: kernel port: N/A
bus-ID: 03:00.1
IF: enp3s0f1 state: down mac:
Device-3: American Megatrends Virtual Ethernet type: USB driver: cdc_ether bus-ID: 1-8.3:3
IF: enxb62de1c40313 state: down mac:
RAID:
Device-1: md2 type: mdraid level: mirror status: active size: 1022 MiB
Info: report: 2/2 UU blocks: 1046528 chunk-size: N/A
Components: Online: 0: nvme0n1p2 1: nvme1n1p2
Device-2: md3 type: mdraid level: mirror status: active size: 474.81 GiB
Info: report: 2/2 UU blocks: 497875968 chunk-size: N/A
Components: Online: 0: nvme0n1p3 1: nvme1n1p3
Drives:
Local Storage: total: raw: 953.88 GiB usable: 477.81 GiB used: 29.16 GiB (6.1%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVL2512HCJQ-00B07 size: 476.94 GiB temp: 33.9 C
ID-2: /dev/nvme1n1 vendor: Samsung model: MZVL2512HCJQ-00B07 size: 476.94 GiB temp: 32.9 C
Partition:
ID-1: / size: 466.29 GiB used: 28.91 GiB (6.2%) fs: ext4 dev: /dev/md3
ID-2: /boot size: 987.4 MiB used: 256.9 MiB (26.0%) fs: ext4 dev: /dev/md2
ID-3: /boot/efi size: 510.7 MiB used: 5 MiB (1.0%) fs: vfat dev: /dev/nvme1n1p1
Swap:
ID-1: swap-1 type: partition size: 512 MiB used: 2.5 MiB (0.5%) dev: /dev/nvme1n1p4
ID-2: swap-2 type: partition size: 512 MiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p4
Sensors:
System Temperatures: cpu: 27.8 C mobo: N/A
Fan Speeds (RPM): N/A
Info:
Processes: 289 Uptime: 12d 21m Memory: 31.23 GiB used: 4.77 GiB (15.3%) Init: systemd
runlevel: 5 Compilers: gcc: 11.4.0 Packages: 1175 Shell: Bash v: 5.1.16 inxi: 3.3.13
