Webmin 1.994
VirtualMin 7.1
RedHat 7
more testing of the new VirtualMin 7.1
Not sure if this post should be in Webmin or Virtualmin …
I have added some custom code in several modules, such as save_domain_php_mode in php-lib.pl with
if (&has_command("chcon")) {
&webmin_log("SELinux context change in save_domain_php_mode", "WVNET-custom",
"etc_t for $inidir/php.ini");
&system_logged("chcon -v --type=etc_t " .
"$inidir/php.ini" .
" >/dev/null 2>&1");
the issue is, when I view these entries in Webmin – Webmin Actions Log, the Executed Command shown for the logged Action is not for that actual entry, but for the next Action entry in the logs
when I remove the webmin_log call, the system_logged items show up as part of the larger Created Virtual Server entry and all is well.
am I calling the routines incorrectly? Maybe my call to webmin_log is messing up other info ‘on the stack’? If so is there an easy fix?
In all cases the actual action I desire is getting accomplished !!
Or am I not understanding how to use/read the Actions Log panel?
Or I should not bother to make an individual log entry for my custom actions since the actual cmd I am doing is in the larger post
Or is this a bug?
Verne
