Webmin backup not working via ssh to remote rush shell
OS type and version (webmin originator) Ubuntu 18.04.6 (target storage) Ubuntu 20.04.1
Webmin version 2.021
I want to make secure backups from Webmin, initially configuration backups, to a remote server. I’m new to Webmin and to rush. This seems to be a config issue with Webmin, rush, or sshd.
My Backup storage server 10.20.0.130 (Ubuntu 20.04) has an account ftpsecure with shell /usr/sbin/rush.
/etc/rush.rc is as follows:
acct on
  limits t10r20
  umask 002
  env - USER LOGNAME HOME PATH
  fall-through
rule pwd
  command ^pwd
  set[0] /bin/pwd
rule scp-to
  command ^scp (-v )?(-r )?-t( --)? /srv/vmceml_backups/?
  set[0] /usr/bin/scp
  chroot /srv/rush
  chdir /srv/vmceml_backups
From my webmin server 10.20.0.129 (Webmin 2.013 on Ubuntu 18.04), I can successfully run:
sudo -u ftpsecure scp -v testfile ftpsecure@10.20.0.130:/srv/vmceml_backups/testfile
No password is requested which proves that the public/private key setup is correct and working, also the verbose log from scp confirms that.
Under Webmin, Backup Configuration Files, Scheduled Backups I have an entry:
Backup destination: SSH server 10.20.0.130
file on server: /srv/vmceml_backups/webmin-vmceml-backups-%Y%m%d.tgz
Login as user ftpsecure
Server port default
Include: Webmin module config files, Server config files.
When I click “Save and Backup Now” I get:
Starting backup of 45 modules to /srv/vmceml_backups/webmin-vmceml-backups-20230307.tgz on 10.20.0.130 via SSH …
scp failed : ftpsecure@10.20.0.130: Permission denied (publickey).
On the backup storage server in /etc/ssh/sshd_config I have:
HostKey /etc/ssh/ssh_host_rsa_key
HostKey /etc/ssh/ssh_host_ed25519_key
LogLevel DEBUG
PermitRootLogin prohibit-password
StrictModes yes
AuthorizedKeysFile .ssh/authorized_keys
HostbasedAuthentication no
IgnoreRhosts yes
PasswordAuthentication no
PermitEmptyPasswords no
PubkeyAuthentication yes
TCPKeepAlive yes
Match User ftpsecure
        ForceCommand internal-sftp
        PermitTunnel no
        AllowAgentForwarding no
        AllowTcpForwarding no
        X11Forwarding no
Match all
ChallengeResponseAuthentication no
UsePAM yes
X11Forwarding yes
X11DisplayOffset 10
PrintMotd no
PrintLastLog yes
TCPKeepAlive yes
AcceptEnv LANG LC_*
Subsystem sftp  /usr/lib/openssh/sftp-server
Note: the presence/absence of the ForceCommand under Match User ftpsecure, or indeed the presence/absence of the entire section Match User ftpsecure, makes no difference.
I have not altered the standard configuration files for PAM.
The restricted shell rush on the backup storage server doesn’t log anything when I run the Webmin backup, not even for the default rule. When I run scp manually on the webmin server then rush on the backup storage server logs as expected against the scp-to rule (and the scp succeeds, as noted above).
I don’t understand the SSHD logs:
KEX done [preauth]
userauth-request for user ftpsecure service ssh-connection method none [preauth]
attempt 0 failures 0 [preauth]
user ftpsecure matched 'User ftpsecure' at line 70
PAM: initializing for "ftpsecure"
PAM: setting PAM_RHOST to "10.20.0.129"
PAM: setting PAM_TTY to "ssh"
Connection closed by authenticating user ftpsecure 10.20.0.129 port 51584 [preauth]
do_cleanup [preauth]
I haven’t been able to find out what scp command exactly, is used by Webmin for these backups, if I knew that I could be sure my manual test corresponds to it.
I got around this by backing up locally and creating a post-backup script to transfer the file using scp, which works. It would be better to be able to do it directly however.
Any suggestions welcome please!
I may be mistaken here, but if you’re running without password authentication it’s not going to ask for a password on your sudo command. That doesn’t prove your keys are set up properly.
I guess this means the keys are set ?
Yes the keys are set, public key in ~ftpsecure/.ssh/authorized_keys on the storage server and private key in ~ftpsecure/.ssh/id_ed25519 on the webmin server. And, scp (from a post-command) works without any password.
Is there a way I can see and perhaps change the command that Webmin is using to attempt backup over ssh? I could try adding “-v” to scp and get a lot more information.
That’s not right.
sshd_config has nothing to do with sudo.
Yes, but the scp succeeds (file gets transferred), and the scp -v log shows a complete authentication sequence.
