Webmin 2.670 does not show logged in users from the "Users and Groups" system module button on Ubuntu 26.04.1 LTS
According to the output webmin both files were updated cleanly
I’m on Rocky 9 and I applied patch and still have the issue too.
I dont’ have a /etc/utmp file maybe the issue?
by some googling I need this file for who to read.
just found this
I ran touch /run/utmp and chown root:utmp /run/utmp; chmod g+w /run/utmp has fixed my issue but there is another with the output.
The output issue with overescaping is fixed too. And on my Rocky 10 system, who works just fine as is.
For some unknown reason on my rocky 9 it was missing that file. who works fine now.
To get it to work (in a fashion) on Ubuntu 26.04 was to replace who version 0.10.0 (what was installed) with who version 9.4 (copied from Ubuntu 24.04) also the utmp fix as @stefan1959 pointed out had to be done.
Note
  • Who version 9.4 is a stand alone program
  • Who (/usr/bin/who) version 0.1.0 is now a symlink to /usr/lib/cargo/bin/coreutils/who
This makes me think that there may be different versions of ‘who’ on different OS’s so it may work fine with your Ubuntu 26.04 test system (which may have a different version of who installed). I researched the problem & found some 26.04 users got this to work others did not. why not see if you can do something with the loginctl utility as it maybe more stable across platforms
