Webmin 2.651 and Usermin 2.550 released
Howdy all,
We’ve rolled out Webmin 2.651 and Usermin 2.550 to all Virtualmin repos.
Changes since Webmin 2.650:
  • Fix Certbot-backed certificate requests and renewals to correctly parse PEM paths after issuance
  • Fix live activation of Linux bond interfaces #2777
  • Update the Authentic theme to the latest version with various improvements and fixes:
    • Fix search-result all-items delete in File Manager
    • Fix search-result delete ordering in File Manager
    • Fix to speed up search-result deletion cleanup in File Manager
Changes since Webmin 2.641 and Usermin 2.540:
  • Add new Systemd Services and Units module
  • Add new GRUB 2 Boot Loader module
  • Add new Kea DHCP Server module
  • Add WebSocket proxy support to the Webmin Servers Index module
  • Add basic Alpine Linux support
  • Add IP-based Let’s Encrypt certificate support with Certbot 5.3
  • Add editable SSH public keys for newly added Unix users in Users and Groups module
  • Add improvements to custom Webmin temporary directory handling
  • Add quick service and port forwarding controls to the nftables module
  • Add optional pre- and post-scripts for scheduled package updates
  • Add option to control when scheduled package update email is sent
  • Add per-user RPC/API-only access option to the Webmin Users module
  • Add Apache 2.4 MPM process limit directives #1821
  • Add dhcpcd network backend for Debian and Raspberry Pi OS #1607
  • Add hardware RAID passthrough devices config in the SMART Status module #1704
  • Update Xterm.js to fix Control-C handling on iPadOS/Safari terminals
  • Update Webmin systemd service unit to run without forking
  • Fix IPv6 CIDR access control matching #1570
  • Fix Bootup and Shutdown module to show only services and not all units on systemd systems
  • Fix Let’s Encrypt renewal scheduling to count from the last successful request
  • Fix NetworkManager detection on Debian and IPv6 DNS nameserver saving
  • Fix Dovecot configuration file handling when saving extra configs
  • Fix mailbox listing to skip unusable Maildir entries and remove stale deleted or moved entries
  • Fix Postfix module labels to identify virtual alias maps instead of virtual mailbox domains #1541
  • Fix Apache module to hide disabled default virtual hosts from the active server list
  • Fix Netplan DNS saving to preserve YAML structure
  • Fix BIND DNS handling of underscores, trailing dots, and mass record length checks
  • Fix MariaDB user creation when using auth plugin syntax
  • Fix PHP-FPM monitor on EL systems when using /etc/php.ini as the config file
  • Fix RPC-only accounts to block browser/module access before module ACL checks
  • Fix reflected XSS in Webmin status messages
  • Fix path validation in File Manager, package delete helpers, and Apache virtual host files
  • Fix authentication state handling for SSL certificate logins and proxied keep-alive requests
  • Update session handling to improve security, which will require users to re-authenticate after upgrading
    • Add zooming to stats history graphs by holding shift and scrolling in the dashboard
    • Add support for saving live stats history for up to 24 hours without performance impact
    • Add better support for the new Nginx, nftables, and upcoming systemd, Kea-DHCP, and GRUB 2 Webmin modules
    • Add ability to always show available dashboard panels in theme configuration
    • Add support for live stats and terminal WebSocket connections through Webmin Servers Index proxy links
    • Fix proxying when Webmin is accessed with a webprefix using Webmin Servers Index module
    • Fix theme UI helpers to escape generated markup more safely
    • Fix iOS terminal viewport sizing
    • Fix editor save handling, clean-state indication and dirty reload guard
    • Fix popover positioning, z-index and border color for help bubbles
    • Fix the active product switch border in the navigation menu for the dark palette
    • Fix to validate password reset return URLs
6 posts were split to a new topic: Usermin 2.550 login from the Virtualmin Edit Users page stopped working
