Ilia
April 5, 2026, 9:34am
1
Howdy all,
We’ve rolled out Webmin 2.630 and Usermin 2.530 to all Virtualmin repos.
Changes since 2.621 and 2.521:
Add improvements to user input validation across all modules
Update Authentic theme to the latest version with various improvements and fixes:
Add a new airy button style to the light palette to match the dark one
Fix to optimize stats server to reduce WebSocket memory usage
Fix the real-time follow indicator when viewing the journal
Fix regex-based match highlighting when viewing the journal
Fix mail compose panel sizing in HTML mode on low-DPR screens
Fix display of the 2FA QR code in the dark palette
Do you mean Webmin 2.630 and Usermin 2.530?
Ilia
April 5, 2026, 3:58pm
3
Yes, you’re right! Thanks for pointing that out! It’s fixed now.
Will the issues brought up with the latest Usermin - hidden OP in Reply and the Trash folder issue be fixed any time soon?
Got the following after updating:
This is not a support topic, neither is the section. It should be kept clean.
If you got questions or in need of help, then open a topic in the corresponding section of the forum.
system
Closed
April 16, 2026, 7:47am
7
