Webmin 2.621 and Usermin 2.521 released
Howdy all,
We’ve rolled out Webmin 2.621 and Usermin 2.521 to all Virtualmin repos.
Changes since 2.620 and 2.520:
  • Fix to prevent NAT from dropping idle RPC sessions during long transfers
  • Fix to improve the message when socket authentication is used in the MySQL/MariaDB module
  • Fix to make upload tracking work correctly in all situations and on all systems
  • Fix to correctly display the PHP version in the PHP Configuration module when managing packages
  • Update Xterm.js to the latest version with lots of improvements and fixes
  • Update Authentic theme to the latest version with various improvements and fixes:
    • Fix the support for the cloned Terminal module
    • Fix error handling for file uploads when the user is out of quota or the system is out of disk space in the File Manager module
    • Fix to stop loading full file into memory for upload check to prevent memory leak on large uploads in the File Manager module
    • Fix to permanently save the state of the navigation menu and right-side slider when toggled
