Howdy all,
I’ve rolled out Webmin 1.500 and Usermin 1.430 to all repositories.
Changes in Webmin since 1.490:
- Fixed an XSS security hole that could be used to capture session cookies, found by Ryan Giobbi.
- Added the Software Package Updates module, for installing new packages from YUM or APT.
- Updated the default system information page to show available packages, and added a page to the Webmin Configuration module to collect this information in the background.
- Added logging to the Scheduled Commands module.
- Fixed editing of the fileset exclude list and adding volume labelling support to the Bacula module.
- Improved Postfix TLS support, fixed the config file parser, and added protection against incorrect map entry deletion.
- Added a status monitoring for detecting large directories, and a button for refreshing just selected monitors.
- Added support for the rsyslog IncludeConfig directive in the System Logs module, used by default on Ubuntu 9.
A detailed change log can be found Webmin.com.
Changes in Usermin since 1.420:
- Autoreply messages starting with or will now be sent using the text/html MIME type.
- Removed limits on the size of an address book group.
- Put text/plain alternative body part before text/html, to be compliant with RFC 2046.
Because the Webmin update includes a security fix, everyone should upgrade to the latest version as soon as possible.
As always, if you run into any problems let us know in the ticket tracker.
