This is a re-post to forums as I posted to the wrong place the first time… Thank you andreychek for pointing me in the right direction!
Hello, First I am a newbie when it comes to this and I am just learning. I have installed virtaulmin on centos 5.3 with the isntall.sh. Everything installed with no issues at all. I created a virtual server and mysql db and loaded WP files into the new virtual sites public_html folder. All the pages were there and the normal wp site was good to go. I then uploaded a new theme and tried to activate it and now I am left with a blank pages in the admin and on the front end. I have searched and search and I think it is a php permission issue but I am not sure. I also had this same issue with just webmin isntalled. I would like someone to help me figure this out and explain how to correct it. You tell me what you need and I will give it to you. Again I am new to all of this so be kind.
andreychek also gave me a couple of things to check and I did. First was to be sure that the files are owned by the virtual server owner and they are. Second was my error log in home/logs/error_log which the last few lines are below. Again I am new at this so please explain in terms I will understand.
error_log:
[Sat Aug 06 04:59:12 2011] [error] [client xxx.xx.xx.xxx] PHP Warning: require_once(/home/dev/public_html/wp-content/themes/genesis/lib/init.php) [function.require-once]: failed to open stream: No such file or directory in /home/dev/public_html/wp-content/themes/outreach/functions.php on line 3, referer: http://dev.mjprostudios.com/wp-admin/themes.php
[Sat Aug 06 04:59:12 2011] [error] [client xxx.xx.xx.xxx] PHP Fatal error: require_once() [function.require]: Failed opening required '/home/dev/public_html/wp-content/themes/genesis/lib/init.php' (include_path='.:/usr/share/pear:/usr/share/php') in /home/dev/public_html/wp-content/themes/outreach/functions.php on line 3, referer: http://dev.mjprostudios.com/wp-admin/themes.php
[Sat Aug 06 04:59:16 2011] [error] [client xxx.xx.xx.xxx] PHP Warning: require_once(/home/dev/public_html/wp-content/themes/genesis/lib/init.php) [function.require-once]: failed to open stream: No such file or directory in /home/dev/public_html/wp-content/themes/outreach/functions.php on line 3
[Sat Aug 06 04:59:16 2011] [error] [client xxx.xx.xx.xxx] PHP Fatal error: require_once() [function.require]: Failed opening required '/home/dev/public_html/wp-content/themes/genesis/lib/init.php' (include_path='.:/usr/share/pear:/usr/share/php') in /home/dev/public_html/wp-content/themes/outreach/functions.php on line 3
[Sat Aug 06 04:59:50 2011] [warn] mod_fcgid: stderr: PHP Warning: require_once(/home/dev/public_html/wp-content/themes/genesis/lib/init.php) [function.require-once]: failed to open stream: No such file or directory in /home/dev/public_html/wp-content/themes/outreach/functions.php on line 3
[Sat Aug 06 04:59:50 2011] [warn] mod_fcgid: stderr: PHP Fatal error: require_once() [function.require]: Failed opening required '/home/dev/public_html/wp-content/themes/genesis/lib/init.php' (include_path='.:/usr/share/pear:/usr/share/php') in /home/dev/public_html/wp-content/themes/outreach/functions.php on line 3
[Sat Aug 06 04:59:51 2011] [warn] mod_fcgid: stderr: PHP Warning: require_once(/home/dev/public_html/wp-content/themes/genesis/lib/init.php) [function.require-once]: failed to open stream: No such file or directory in /home/dev/public_html/wp-content/themes/outreach/functions.php on line 3
[Sat Aug 06 04:59:51 2011] [warn] mod_fcgid: stderr: PHP Fatal error: require_once() [function.require]: Failed opening required '/home/dev/public_html/wp-content/themes/genesis/lib/init.php' (include_path='.:/usr/share/pear:/usr/share/php') in /home/dev/public_html/wp-content/themes/outreach/functions.php on line 3
[Sat Aug 06 05:32:18 2011] [warn] mod_fcgid: stderr: PHP Warning: require_once(/home/dev/public_html/wp-content/themes/genesis/lib/init.php) [function.require-once]: failed to open stream: No such file or directory in /home/dev/public_html/wp-content/themes/outreach/functions.php on line 3
[Sat Aug 06 05:32:18 2011] [warn] mod_fcgid: stderr: PHP Fatal error: require_once() [function.require]: Failed opening required '/home/dev/public_html/wp-content/themes/genesis/lib/init.php' (include_path='.:/usr/share/pear:/usr/share/php') in /home/dev/public_html/wp-content/themes/outreach/functions.php on line 3
