OS type and version
AlmaLinux 8.10
Webmin version
2.202
Virtualmin version
7.20.2
Webserver version
Ubuntu
I installed the new packages and rebooted the system, but now my site is not working and I’m getting the following error. Could you please help me with this?
Can you copy and paste from this icon as Webserver: Ubuntu makes no sense.
Are all servers running ok, maybe mariadb is down? Although connection refused maybe means its up.
How can I fix this issue? Do I need to adjust any settings?
Who knows, need to get a error log to try and work whats going on. What updates did you do?
stefan1959:
mariadb is down
mariadb is down. Its working now. Thanks
you get any error when you try a restart of the database
systemctl restart mariadb
then run systemctl status mariadb
Thats not normal. I’ve never had mariadb not startup during reboot, hopefully its a once off.
Does the farmerfirst have permissions in the Edit Virtual Server
system
Closed
November 15, 2024, 5:04pm
12
