I have a VPS with fixed IP xx.xx.xx.xx and have chosen Hostname : myVPS (is it ok to do this)?
I have installed myDomain1 and myDomain2 *both.com)
Question 1. How many virtual server does that count for? 2 - just the domains? or 3 - the domains + the VPS container itself?
Question 2. I have been able to install Let’s Encrypt on the domains.
But not so on Webmin. Don’t know how. When I log into Webmin https://xx.xx.xx.xx:10000
the connection is not secure.
Why is that and what can I do to make it secure?
Domains and sub-domains are counted against license quota, while aliases not.
Question 2. I have been able to install Let’s Encrypt on the domains. But not so on Webmin. Don’t know how. When I log into Webmin
Post installation wizard can offer you to create a default virtual server (which you can use to connect to Webmin as well) and request Let’s Encrypt certificate for it. This default domain is not counted against total domains quota.
You could re-run the wizard by going to System Settings > Re-Run Install Wizard page.
Thanks Ilia,
my further question is also related to my conversation with calport.
If I create a default virtual server - must I supply a FQDN? Must it exist or can it be ficticious?
I use hostinger. their hpanel allows me to set the hostname right there. Should I set the FQDN there?and should that be the one that I create the default virtual server with? Are the two things related?
“A fully qualified domain name, sometimes also referred to as an absolute domain name, is a domain name that specifies its exact location in the tree hierarchy of the DNS.”
