Greetings,
Kindly appreciate any help on this issue.
I installed Virtualmin with installer script.
I installed on a minimal and clean grade-A supported OS .
My OS is Centos7.2. I also did the same tests with Centos 6.9.
The FCGI enabled as well.
The Wordpress installed under /home/domainname/public_html.
The owner of the directories where Wordpress needs to write files IS the virtual server owner user, all parent directories starting at /home. Is the same user.
The owner of the domain. T
he permissions set to 755 on all the files of the domain home directory.
Here is the output:
[root@srv public_html]# pwd
/home/example/public_html
[root@srv public_html]# ls -lah
total 208K
drwxr-xr-x 6 example example 4.0K Mar 12 15:51 .
drwxr-xr-x 11 example example 4.0K Mar 12 15:38 …
-rwxr-xr-x 1 example example 35 Mar 12 15:38 .htaccess
-rwxr-xr-x 1 example example 418 Mar 12 15:37 index.php
-rwxr-xr-x 1 example example 20K Mar 12 15:50 license.txt
-rwxr-xr-x 1 example example 7.3K Mar 12 15:50 readme.html
drwxr-xr-x 2 example example 4.0K Mar 12 15:36 stats
-rwxr-xr-x 1 example example 5.4K Mar 12 15:37 wp-activate.php
drwxr-xr-x 9 example example 4.0K Mar 12 15:37 wp-admin
-rwxr-xr-x 1 example example 364 Mar 12 15:37 wp-blog-header.php
-rwxr-xr-x 1 example example 1.6K Mar 12 15:37 wp-comments-post.php
-rwxr-xr-x 1 example example 3.1K Mar 12 15:37 wp-config.php
-rwxr-xr-x 1 example example 2.8K Mar 12 15:37 wp-config-sample.php
drwxr-xr-x 6 example example 4.0K Mar 12 15:51 wp-content
-rwxr-xr-x 1 example example 3.6K Mar 12 15:37 wp-cron.php
drwxr-xr-x 18 example example 12K Mar 12 15:37 wp-includes
-rwxr-xr-x 1 example example 2.4K Mar 12 15:37 wp-links-opml.php
-rwxr-xr-x 1 example example 3.3K Mar 12 15:37 wp-load.php
-rwxr-xr-x 1 example example 36K Mar 12 15:37 wp-login.php
-rwxr-xr-x 1 example example 7.9K Mar 12 15:37 wp-mail.php
-rwxr-xr-x 1 example example 16K Mar 12 15:37 wp-settings.php
-rwxr-xr-x 1 example example 30K Mar 12 15:37 wp-signup.php
-rwxr-xr-x 1 example example 4.6K Mar 12 15:37 wp-trackback.php
-rwxr-xr-x 1 example example 3.0K Mar 12 15:37 xmlrpc.php
I’m not able to publish the website from wordpress. Error message:
Looks like something’s gone wrong. Wait a couple seconds, and then try again.
Also I’m not able to upload any image on the site.
Here is the error message:
HTTP error.
Please share some light on this.
This is for better view.
