I am setting up a new server, on CENTOS5.2, on SLICEHOST, a virtualserver hosting solution.
My Virtualmin installation was going great. I was able to get it to load. I was checking everything that the configuration was good and it was saying that I had an issue with the "network interface".
I set the IP address to the static IP address of the server in the network interface area, only changed that one setting, and rebooted the server.
After this, the virtualmin webpage refuses to load up but my default page on the server will load fine.
What did I affect? I am able to SSH to the sever. Is there a config file that I can edit via command-line to get myself back on track? I want to revert my one change back and make sure I am all good.
Thanks for any help you can provide.
Kyle
