I am running Ubuntu 9.10 and for some reason my Virtualmin/Webmin install will not load on startup. I have to manually go in and start webmin. Then I go to Bootup and Shutdown and try to tell it to start on bootup. But it doesnt seem to “save” that configuration change.
During your server’s bootup, and also when you try to add Webmin to the startup – are you seeing any errors in the Webmin error log? That’s in /var/webmin/miniserv.error.
Okay, so just to be clear – what you did is go into Bootup and Shutdown, check the box next to “Webmin”, and at the bottom of the screen where all the buttons are, you clicked “Start on Boot”.
After you do that – does it still say “No” in the “At Boot?” column?
