The server itself is working fine, however immediately after webmin updated to 1.881-1, virtualmin validation started sending out errors about MySQL. No other changes were made to system.
In this setup, webmin/virtualmin is running on one server, and MySQL is running on a seperate decated DB server. MySQL is not running on the web server (webmin/virtualmin server) The DB server does not have webmin or virtualmin installed. Everything still seems to work fine (adding users, adding DBs, permissions, etc from within Webmin/virtualmin.
If I run the re-check configuration, it gives the same warning. the remote server is configured in “mysql servers”,
I’m guessing this is some kind of setting configuration issue where I don’t have webmin configured correctly for the new Mysql servers seetting added in vitrualmin 6.01
MySQL does not appear to be installed and running on your system, or has not yet been set up properly in Webmin’s MySQL Database module. If your system does not use MySQL, it should be disabled in Virtualmin’s module configuration page.
I’m afraid to disable the module on the configuration page, since in past versions disabling the module removed ability to manage databases on a seperate DB server from within virtualmin. What is the correct configuration settings for when mysql is NOT running or installed on the web server (running webmin/virtualmin) and the only DB server is an external seperate DB server?
