VirtualMin through Webmin
My server came with LAMP + Webmin…
Now i wish to install VirtualMin…
Please tell me a bit more detailed instructions on how to do it…
Im on CentOS 7.3 (64 Bit)
Its a fresh install, i have not done anything else yet!
Maybe remove the Hosting Provided WebMin and install VirtualMin all together? I dont know how
Very new to all these server related stuff…
Please guide me…
If Webmin was installed using the standard Webmin package (the RPM from Webmin.com), you can just run the install script. It’ll work fine.
If it was not installed using a standard package, you’ll need to uninstall it first. How it was installed will determine how you uninstall it (and I don’t know that information). If a non-standard rpm, use “rpm -e webmin”. If a tarball install, run the uninstall.sh script in the /etc/webmin directory. (Actually, it looks like Webmin is smart enough to know how it was installed, and so running /etc/webmin/uninstall.sh will always do the right thing.)
