Virtualmin tells me awstats is already activated when it is not installed
OS type and version Ubuntu Linux 18.04.6
Webmin version 1.991
Virtualmin version 7.0-4 Pro
Hello… I have moved a domain from an old server to a new one. When I did so the “restore” option would not work so I needed to just create the domain on the new server and then copy the necessary files. Awstats was functional on the old site and so those files were copied along with the others.
When I go to edit the server and turn Awstats on, Virtualmin responds that the action fails because Awstats is already installed. It’s not the end of the world because Webalizer does work… but I’d like to fix this and have Awstats work as well. How can I fix the problem?
Please double check that webmin-virtualmin-awstats package is installed. Also, check that it’s actually enabled in System Settings ⇾ Features and Plugins page.
