I can’t find a specific example of this in the forums so I hope it hasn’t been covered before but since using Subservers I’m finding the PHP upload_max_filesize limits set against the global PHP configuration are not working, sites always show the default 2M limit.
To answer a couple of quick questions:
- PHP configurations all set to 10M (see below)
- Apache has been restarted on multiple occasions
- PHP script in use is FCGid
- Websites have no overriding php.ini files or .htaccess file size restrictions
To explain the scenario a little better…
I have a virtual server e.g. toplevel.com
Then sub-servers (not alias servers) for customer sites for demo and upgrade purposes, e.g.
toplevel.com > customersite1.com
toplevel.com > customersite2.com
Using Wordpress or Joomla when I want to upload a plugin or file to upgrade there is always a 2M file size limit. Yet on the PHP settings its set to 10M.
This is where I have 10M set:
webmin > others > php configuration
Maximum file upload size = 10M
Maximum HTTP POST size =10M
Checking the /etc/php.ini file it clearly shows upload_max_filesize = 10M.
Going into the server (toplevel.com) > Services > PHP 7.2 Configuration > Resources
Again checking /home/toplevel.com/etc/php7.2/php.ini shows upload_max_filesize = 10M.
To the subserver > Services > PHP 7.2 configuration > Resources
And again checking /home/toplevel.com/domains/customersite1.com/etc/php7.2/php.ini shows upload_max_filesize = 10M.
When I go to a different top level site on the same server (not a sub-server) and check the upload file limit, its correctly set at 10M and a file can be uploaded to Wordpress or Joomla correctly, so I can be sure the global setting of 10M is set correctly and working.
But when I open one of the sub-server sites, either Wordpress or Joomla, the upload file limit is always 2M.
Using Joomla as an example, I can check the System Information > PHP settings, it shows its reading the php.ini file from the sub-server domains area e.g.
But it shows upload_max_filesize = 2M, not the 10M it states when looking directly at the php.ini file?!
I’m stumped, no clue why its doing this but hopefully its just something stupid I’ve missed on sub-servers, any help would be greatly appreciated.
