Hi, I know there are numerous refernences on this on the forum, but I’m after the latest upto recomendation on this. Thanks
Just about to reinstall / replace our current virtualmin server, our current old install runs under KVM.
I know people are running virtualmin in openvz ct, but I have the option to run under either openvz or KVM, from your experiences aby reason why I would or would not use openvz.
Garry
PPS
OK found this: “If you find this forum thread because your having issues with quotas on your OpenVZ VPS then you’re at the right spot! This issue has been diagnosed and solved and will be included in the next virutalmin release”.
At: https://www.virtualmin.com/node/24774
BY: Thanks Jamie and Eric!
Can the fix be eeasily applied to a current release of virtualmin or need to wait for next release?
