I get this message every time I log in, I imagine it’s a bug:
Your system has 9.61 GB of memory, which is at or above the Virtualmin recommended minimum of 256 MB.
Too much memory ? lol
Hmm, that message is normally seem by going into System Settings -> Re-Check Config… it’s part of the output there, and just says that your server has enough RAM.
Where are you seeing that though?
Hi Eric,
Every time I log in it says that I need to recheck the configuration, when I do it then displays the message. Where you suggested I go gives the same result.
Hope these print screens help
Hi Eric,
Aha – the key is the error Virtualmin is throwing… not the first message regarding to the RAM, but the second one regarding DNS.
If you fix that DNS issue I think that’ll resolve the issue you’re seeing there.
