Hi Eric,
it doesn’t work yet. This is the output:
Checking Configuration
Your system has 3.86 GB of memory, which is at or above the Virtualmin recommended minimum of 256 MB.
Il server DNS BIND è installato.
Postfix can support per-domain outgoing IP addresses, but is not currently configured to do so. This can be setup in the Postfix Mailserver module.
Apache is installed.
The following PHP versions are available : 5.5.9 (/usr/bin/php5-cgi)
Webalizer is installed.
Apache is configured to host SSL websites.
MySQL is installed and running.
ProFTPd is installed.
Logrotate is installed.
SpamAssassin and Procmail are installed and configured for use.
ClamAV is installed and assumed to be running.
Plugin AWstats reporting is installed OK.
Plugin Mailman is installed OK.
Plugin Protected web directories is installed OK.
Using network interface eth0 for virtual IPs.
IPv6 addresses are available, using interface eth0.
Default IPv4 address for virtual servers is 95.110.155.185.
Virtualmin could not work out the default IPv6 address for virtual servers on your system. You will need to update either the Network interface for virtual addresses or Default virtual server IP address fields on the module configuration page.
Default IP address is set to 95.110.155.185, which matches the detected external address.
Quote non abilitate nel filesystem / che contiene la directory home /home e i file email sotto /home. Modifica quote disabilitata.
All commands needed to create and restore backups are installed.
The selected package management and update systems are installed OK.
… il tuo sistema è pronto per usare Virtualmin
I cannot edit my quotes.
