Hi there,
I recently got a vm pro license and tried to install it on SLES 10 but with little success. The install script seems to execute ok but doesn’t appear to complete fully:
Checking for curl or wget…found /usr/bin/curl -O
Checking for perl…found /usr/bin/perl
Loading log4sh logging library…
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 21395 100 21395 0 0 73269 0 --:–:-- --:–:-- --:–:-- 108k
INFO - Started installation log in virtualmin-install.log
INFO - Checking for fully qualified hostname…
INFO - Hostname OK: fully qualified as xyz.abc.com
INFO - Installing serial number and license key into /etc/virtualmin-license
INFO - Loading OS selection library…
100 4448 100 4448 0 0 36810 0 --:–:-- --:–:-- --:–:-- 173k
INFO - Succeeded.
100 2983 100 2983 0 0 27400 0 --:–:-- --:–:-- --:–:-- 224k
INFO - Succeeded.
INFO - ***********************************************************************
INFO - Operating system name: SuSE Linux
INFO - Operating system version: 10
INFO - Installing dependencies using command:
I was able to successfully install webmin and the gpl version of virtualmin. So how do I get the pro version working? I’m running Suse Linux enterprise server 10, apache2 but no mysql on this box (db is on another server). I also tried downloading the wbm from http://software.virtualmin.com/wbm but my login id is not accepted.
Can someone point me in the right direction here?
Thanks in advance.
