| SYSTEM INFORMATION | |
| OS type and version | Debian Linux 12 |
| Webmin version | 2.653 |
| Virtualmin version | 8.1.0 Professional |
| Webserver version | Apache/2.4.68 (Debian) |
| Related packages | Ghost (Virtualmin Pro Web App Installer) |
Updated to Virtualmin Pro today just to get the Ghost install script and got these errors:
added 563 packages in 6m
92 packages are looking for funding
run `npm fund` for details
Love open source? We’re hiring JavaScript Engineers to work on Ghost full-time.
https://careers.ghost.org
- Inspecting operating system
- Checking for deprecations
[17:54:52] Checking for Ghost-CLI updates [started]
[17:54:53] Checking for Ghost-CLI updates [completed]
- Checking for latest Ghost version
✔ Checking for latest Ghost version
[17:54:56] Checking system Node.js version [started]
[17:54:56] Checking system Node.js version - found v22.19.0 [title changed]
[17:54:56] Checking system Node.js version - found v22.19.0 [completed]
[17:54:56] Checking current folder permissions [started]
[17:54:56] Checking current folder permissions [completed]
[17:54:56] Checking memory availability [started]
[17:54:56] Checking memory availability [completed]
[17:54:56] Checking free space [started]
[17:54:56] Checking free space [completed]
[17:54:56] Checking SQLite build dependencies [started]
[17:54:56] Checking SQLite build dependencies - found Python v3.11.2 [title changed]
[17:54:56] Checking SQLite build dependencies - found Python v3.11.2 [completed]
[17:54:56] Setting up install directory [started]
[17:54:56] Setting up install directory [completed]
[17:54:56] Downloading and installing Ghost [started]
[17:54:56] Downloading and installing Ghost v6.19.3 [title changed]
[17:54:56] Getting download information [started]
[17:54:58] Getting download information [completed]
[17:54:58] Downloading [started]
[17:56:51] Downloading [completed]
[17:56:51] Installing dependencies [started]
[17:56:53] → yarn install v1.22.22
[17:56:56] → [1/5] Validating package.json...
[17:56:56] → [2/5] Resolving packages...
[17:57:21] → [3/5] Fetching packages...
[18:00:28] → info There appears to be trouble with your network connection. Retrying...
[18:01:01] → info There appears to be trouble with your network connection. Retrying...
[18:01:35] → info There appears to be trouble with your network connection. Retrying...
[18:01:48] → info There appears to be trouble with your network connection. Retrying...
[18:02:08] → info There appears to be trouble with your network connection. Retrying...
[18:02:22] → info There appears to be trouble with your network connection. Retrying...
[18:02:44] → info Visit https://yarnpkg.com/en/docs/cli/install for documentation about this command.
[18:02:56] → info There appears to be trouble with your network connection. Retrying...
[18:03:29] → info There appears to be trouble with your network connection. Retrying...
[18:07:20] → info There appears to be trouble with your network connection. Retrying...
[18:10:14] → info There appears to be trouble with your network connection. Retrying...
[18:10:48] → info There appears to be trouble with your network connection. Retrying...
[18:11:21] → info There appears to be trouble with your network connection. Retrying...
[18:11:54] → info There appears to be trouble with your network connection. Retrying...
[18:12:20] → info There appears to be trouble with your network connection. Retrying...
[18:13:19] → info There appears to be trouble with your network connection. Retrying...
[18:15:25] → info There appears to be trouble with your network connection. Retrying...
[18:15:58] → info There appears to be trouble with your network connection. Retrying...
[18:16:33] → info There appears to be trouble with your network connection. Retrying...
[18:17:06] → info There appears to be trouble with your network connection. Retrying...
[18:21:41] → info There appears to be trouble with your network connection. Retrying...
[18:22:14] → info There appears to be trouble with your network connection. Retrying...
[18:22:48] → info There appears to be trouble with your network connection. Retrying...
[18:23:21] → info There appears to be trouble with your network connection. Retrying...
[18:24:38] Installing dependencies [failed]
[18:24:38] → Command failed: yarn install --no-emoji --no-progress
warning ghost@6.19.3: The engine "cli" appears to be invalid.
warning Lockfile has incorrect entry for "@tryghost/errors@1.3.8". Ignoring it.
warning Resolution field "@tryghost/errors@1.3.8" is incompatible with requested version "@tryghost/errors@^1.3.9"
warning Resolution field "moment@2.24.0" is incompatible with requested version "moment@^2.29.4"
warning Resolution field "moment@2.24.0" is incompatible with requested version "moment@^2.27.0"
warning Resolution field "moment@2.24.0" is incompatible with requested version "moment@2.27.0"
warning Resolution field "@tryghost/errors@1.3.8" is incompatible with requested version "@tryghost/errors@1.3.6"
warning Resolution field "@tryghost/logging@2.5.0" is incompatible with requested version "@tryghost/logging@2.4.19"
warning Resolution field "jackspeak@2.3.6" is incompatible with requested version "jackspeak@^3.1.2"
error Error: https://registry.yarnpkg.com/@faker-js/faker/-/faker-7.6.0.tgz: ESOCKETTIMEDOUT
at ClientRequest. (/home/domain/public_html/ghostblog/node_modules/yarn/lib/cli.js:142037:19)
at Object.onceWrapper (node:events:633:28)
at ClientRequest.emit (node:events:519:28)
at TLSSocket.emitRequestTimeout (node:_http_client:863:9)
at TLSSocket.emit (node:events:531:35)
at Socket._onTimeout (node:net:604:8)
at listOnTimeout (node:internal/timers:588:17)
at process.processTimers (node:internal/timers:523:7)
[18:24:38] Downloading and installing Ghost v6.19.3 [failed]
A ProcessError occurred.
Debug Information:
OS: Debian GNU/Linux, v12
Node Version: v22.19.0
Ghost-CLI Version: 1.31.1
Environment: development
Command: 'ghost install 6.19.3 --port 3000 --url http://domain.com/ghostblog local'
Additional log info available in: /home/domain/.ghost/logs/ghost-cli-debug-2026-08-17T01_24_38_733Z.log
Try running ghost doctor to check your system for known issues.
You can always refer to https://ghost.org/docs/ghost-cli/ for troubleshooting.
When going to the link under the install terminal output the page gives a “Forbidden” error.
Any suggestions on what I an do to complete the installation?
John
