Hello!
I’d like to copy the backup of my entire webserver to a Google Account. Now, I’ve seen that there is the Pro version of virtualmin.
Does this version include this feature?
Thanks!
Hello!
Thanks!
Google Cloud Storage Cloud Storage | Google Cloud is available in Pro. I dont use it myself but BackBlaze so cant confirm if its working OK, assume it does. Encryption keys also available in Pro, just make sure you backup that as without it you wont be able to extract encrypted backups.
i use rclone to mount google drive as a local folder
https://rclone.org/
then i backup virtual server on that folder , for now works fine
@asimpledeveloper best way would be to ask yourself directly to them @staff …they will reply shortly.
