Virtualmin Pro 7.7 installation failed on RHEL 9.1
OS type and version RHEL 9.1
Webmin version 2.021
Virtualmin version 7.7 Pro
Hi, the default installation command displayed in my account after purchase fails.
[INFO] Started installation log in /root/virtualmin-install.log
▣:white_medium_square::white_medium_square: Phase 1 of 3: Setup
Installing core plugins for package manager :heavy_check_mark:
Downloading Virtualmin 7 release package :heavy_check_mark:
Installing Virtualmin 7 release package :heavy_check_mark:
▣▣◻ Phase 2 of 3: Installation
Enabling Red Hat CodeReady package repository :heavy_check_mark:
:heavy_check_mark:
Installing EPEL 9 release package :heavy_check_mark:
Cleaning up software repo metadata :heavy_check_mark:
Checking and installing system packages updates [ERROR] Failed with error: 1
[ERROR] Something went wrong. Exiting.
[ERROR] The last few log entries were:
Installing EPEL 9 release package: Success.
Spin pid is: 18861
Updating Subscription Management repositories.
17 files removed
Cleaning up software repo metadata: Success.
Spin pid is: 18923
Extra Packages for Enterprise Linux 9 - x86_64 1.4 MB/s | 15 MB 00:10
Red Hat CodeReady Linux Builder for RHEL 9 x86_ 9.6 B/s | 10 B 00:01
Errors during downloading metadata for repository ‘codeready-builder-for-rhel-9-x86_64-eus-debug-rpms’:
  • Status code: 404 for https://cdn.redhat.com/content/eus/rhel9/9/x86_64/codeready-builder/debug/repodata/repomd.xml (IP: 184.51.36.251)
    Error: Failed to download metadata for repo ‘codeready-builder-for-rhel-9-x86_64-eus-debug-rpms’: Cannot download repomd.xml: Cannot download repodata/repomd.xml: All mirrors were tried
    Checking and installing system packages updates: [2023-04-24 07:04:02 CDT] [ERROR] Failed with error: 1
    [2023-04-24 07:04:02 CDT] [ERROR] Something went wrong. Exiting.
    [2023-04-24 07:04:02 CDT] [ERROR] The last few log entries were:
I managed to resolve the issue by first installing GPL version and then using the upgrade tool to go to Pro. Question is why the command failed? If i am to repeat this on a new install, it would also fail. Maybe the script needs to be updated?
I have had issues with RHEL and the Virtualmin installer before too. It looks like the installer has enabled the incorrect repositories, as unless you have a subscription for EUS (Extended Update Support), it will fail.
In Terminal, check which repos are enabled by typing:
$ subscription-manager repos --list-enabled
This is the output from a RHEL 8 system I had to hand (similar repos are needed for 9):
    Available Repositories in /etc/yum.repos.d/redhat.repo
Repo ID:   rhel-8-for-x86_64-appstream-rpms
Repo Name: Red Hat Enterprise Linux 8 for x86_64 - AppStream (RPMs)
Repo URL:  https://cdn.redhat.com/content/dist/rhel8/$releasever/x86_64/appstream/os
Enabled:   1
Repo ID:   rhel-8-for-x86_64-baseos-rpms
Repo Name: Red Hat Enterprise Linux 8 for x86_64 - BaseOS (RPMs)
Repo URL:  https://cdn.redhat.com/content/dist/rhel8/$releasever/x86_64/baseos/os
Enabled:   1
Repo ID:   codeready-builder-for-rhel-8-x86_64-rpms
Repo Name: Red Hat CodeReady Linux Builder for RHEL 8 x86_64 (RPMs)
Repo URL:  https://cdn.redhat.com/content/dist/rhel8/$releasever/x86_64/codeready-builder/os
Enabled:   1
Might be a bug in the pro installer?
I use Redhat Free Subscription (the one with 16 servers), no extended support.
The problem the installer encountered was that it tried to use the following repository:
And you’re on a developer license which doesn’t have access to EUS.
I understand. I guess it doesn’t use it for upgrade from free to pro?
