I’m trying out Virtualmin to see how it feels and I’ve hit an issue involving a cron job being launched by Virtualmin on /etc/webmin/virtual-server/collectinfo.pl which is failing every 5 minutes with :
Error: Failed to query Postfix config command to get the current value of parameter process_id_directory: <tt></tt>
Error
Now the file is definitely there, I can access the parameter using postconf on the command line, Virtualmin and Postfix both seem to be working fine, although I’m running it all on a VPS which maybe becoming little tight on memory.
Any bright ideas why this is happening and how to stop it?!
Thanks for listening!
