Virtualmin Panel forbidden
This is a panel and it is forbidden, why ? it was working, I add new domain, set their ssl, ssl worked for that domain, now the whole ip is forbidden, even the panel, can’t login, can’t even found server for https://ipadress:1000 I disabled fail2ban too, etc etc ect nothing worked
Your URL above shows using port 1000… you’d want to ensure you’re using port 10000, or else you’d receive an error.
I mean 10000
after i add another domain and do ssl on that with comodo
the panel which is on another domain with same ip virtualmin panel can’t find server
I have fixed it, something in server conf was wrong
