Ned
1
I have a problem with Virtualmin Package updates.
When i login to root account in virtualmin i see this:
Package updates 3 package updates are available
But when i click on the link, i see:
No packages available to be updated were found.
Please, can anyone tell me what I need to do to remove these “empty” updates?
Thanks in advance!
Eric
2
Hmm, what distro/version is it that you’re using there?
Ned
3
Hi Eric,
I use Debian Linux 8 32 bit
Eric
4
Okay, I’m curious what you see if you try running updates from the command line.
So in your case, what output do you see if you run this command:
apt-get update && apt-get upgrade
Does that show any packages? Or does it say you’re up to date?
Ned
5
Hi Eric!
I run the above commands.
Two software packages are updated:
openjdk-7-jre and openjdk-7-jre-headles
So now i have only one update that not showing…
Ned
6
I run the above commands for second time…
The system downloads one update, but when i run:
apt-get upgrade
In the end it gives me:
The following packages have been cept back:
vdpau-va-driver
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Ned
7
Finally!
I used Synaptic Package Manager and updated the vdpau-va-driver.
Now everything is OK!
Thank you Eric!
