Virtualmin not creating SSL virtual website
When I create a new subserver and select the "Create SSL Website" option. Everything appears to work OK with no errors.
But when I visit the new SSL website I get:
SSL received a record that exceeded the maximum permissible length.
(Error code: ssl_error_rx_record_too_long)
I check Apache and see that no Virtual SSL host was created. This is the only part that is missing.
When I delete the Virtual Subserver,
Deleting SSL virtual website …
… no Apache virtual host found!
I am using Mac OS X 10.5.2 Server
I found out that if you first create the virtual server WITHOUT the "SSL Website" option enabled, then go back and add it in later, it works OK.
Sounds like a bug. Probably ought to file a ticket.
