Virtualmin Nginx and Virtualmin Nginx SSL modules 3.1.0 released
We’ve rolled out version 3.1.0 of the Virtualmin Nginx and Virtualmin Nginx SSL modules to all repos.
Changes since the last release:
  • Add HTTP/3 support for SSL-enabled domains
  • Add support for IPv6-only domains and improved listener handling during IP changes and restores
  • Add filename and query-string options for Nginx redirects
  • Fix Nginx directory alias handling
  • Fix redirects that exclude .well-known paths
  • Fix X-Forwarded-Proto for proxy backends
  • Fix SSL certificate chain synchronization
As always, if you run into any problems, let us know in a new topic.
