Virtualmin nginx and nginx-ssl module versions 2.32 and 1.20
virtualmin-nginx changes since 2.31:
  • Fix preserving of PHP mode when cloning
  • Fix case where no port is allocated
  • Fix to setup default PHP error log
  • Fix to properly disable website
virtualmin-nginx changes since 2.30:
  • Always proxy WebSockets
virtualmin-nginx-ssl changes since 1.19:
  • Fix to break SSL linkage when cloning a domain
As always let us know about any problems you run into in a new topic, including the problem you’re seeing and any errors you get.
