hello,
i just wondering if anyone can give me hand with the installation of virtualmin and multicraft (hosting minecraft servers plus website)
i got a centos dedicated server.
ok so i properly installed virtualmin and works fine, i added a new domain and loads up properly. Now when i try to install multicraft the installation completed with no error between both (virtualmin and Multicraft), the issues im having is that virtualmin mmm wont find or locate multicraft wont load the webpage. so i cant finish the configuration of the multicraft installation if i cant load multicraft webpage.
i search around the forum and there is none topic related to multicraft thats why i wanted to create a post and ask. (apologies if this is not the correct section)
thank you!
(sorry for my English.)
