I’ve got several mailing lists set up on different domains in Virtualmin. Unfortunately, the Sender: header of the administrative emails is always mailman-bounces@localhost.localdomain, whereas the From: header is correct: listname-owner@correctdomain.com.
This is causing messages to be rejected by moderators’ email systems.
How can I get the senders to align?
Here’s a snippet of the received email (on an email server that accepted it):
Hmm, I just checked the email that went to another moderator, and it seems to have the right domain in the Errors-to: and Sender: headers. I wonder if I change the order of the moderators in the list if I see whether it only happens to the first one?
Let’s see if I can get the tags right here:
To: thelist-owner@domain.org
MIME-Version: 1.0
Content-Type: multipart/mixed; boundary="===============0237713326=="
Message-ID: mailman.143.1398181304.1486.thelist@domain.org
Date: Tue, 22 Apr 2014 08:41:44 -0700
Precedence: bulk
X-BeenThere: thelist@domain.org
X-Mailman-Version: 2.1.14
List-Id: Directors and committee chairs of DOMAIN<thelist.domain.org>
X-List-Administrivia: yes
Errors-To: mailman-bounces@localhost.localdomain
Sender: mailman-bounces@localhost.localdomain
Apparently the Sender: address is used in the SMTP handshake:
Apr 22 08:41:47 va postfix/smtp[17643]: E23771700B27: to=amoderator@adomain.com, relay=toolworks.com[192.249.122.237]:25, delay=0.44, delays=0.04/0.01/0.32/0.07, dsn=5.0.0, status=bounced (host adomain.com[192.249.122.237] said: 550-Verification failed for mailman-bounces@localhost.localdomain 550-Unrouteable address 550 Sender verify failed (in reply to RCPT TO command))
No, it’s still a problem. The other moderator’s email address was more tolerant of a bogus sender.
Note that this only happens with the moderator notifies; the email that gets sent back to the original sender has the correct domain for the Sender: header.
Okay, well, I changed the DEFAULT_EMAIL_HOST in /etc/mailman/mm_cfg.py to the canonical hostname, and now it sends that as the host in the Sender: header for notices to moderators.
So that fixes it, though I’m surprised this isn’t already overridden somewhere else.
