I’ve update te ip where i found the old, but now virtualmin is showing this message
“Your system’s primary IP address appears to have changed from ******* to *********. Virtual servers using the old address may be unreachable or serve the wrong web content.”
there’s a guide to update ip in virtaulmiin /webmin?
What do you have configured for the page “System Settings -> Virtualmin Configuration -> Networking Settings”? Can you take a screenshot of that? Please take a screenshot too of the page “Addresses and Networking -> Shared IP Addresses”.
Okay, I think it’s possible that the old IP is still noted somewhere in your network configuration. You might want to search through all files in /etc for the old IP. Otherwise I’m a bit stumped as to why Virtualmin should use the old IP in newly created virtual servers…
Your VPS is OpenVZ based, you should restart it so that the networking configuration can get completely refreshed. If you manually make changes to /etc/hosts or /etc/resolv.conf they will be overwritten on reboot.
I guess it can… Unfortunately I’m not familiar with that type of virtualization network interface… Hopefully someone who is will barge in here. My suggestion would be removing the incorrect assignment and making the correct one “venet0:0” or “venet0”. But I can’t say what implications that has.
