Virtualmin installing centos 9 stream
OS type and version CentOS Stream Linux 9
Webmin version 2.001
Virtualmin version 7.3
I greet everyone first .
I want to run centos 9 stream virtualmin.
I am asking for your help to complete the installation
I’m having trouble setting it up completely.
mainly Dns setup and Nameserver setup and adding domain
It works after redirecting the domain. It doesn’t work after 1-2 hours. It is impossible to understand the reason. my domain name http://www.geniuserver.info/
I want to learn full control so I can help everyone. For example, there are poor people in some countries who can’t afford Vps or hosting because it’s expensive, so I’m thinking of offering it for free so they can run their own projects.
When you write it like this, you can see it, but you can’t enter it by writing the domain name, it suddenly stopped working by itself
https://213.154.13.240:10000/virtual-server/link.cgi/192.168.1.100/http://www.srv1.geniuserver.info/
If there is an expert, I can investigate the issue and give you the password of the server
I made it, but I did it without fully understanding the explanation
geniuserver.info working website check please
I recommend you not do that. CentOS Stream is not a Grade A supported OS (and may diverge from a working state in subtle or not subtle ways at any point in the future), and unless you’re an expert, you should stick to a Grade A supported OS.
I recommend you use Rocky, Alma, or RHEL.
Thank you, my first order of business tomorrow will be to do what you said.
Thank you for taking your valuable time to write a reply
