Virtualmin installation on centos
OS type and version Centos 7
Webmin version REQUIRED
Virtualmin version REQUIRED
I used following script but currently it is not working
sudo yum -y update
sudo yum -y install perl
sudo yum install wget
wget http://software.virtualmin.com/gpl/scripts/install.sh
sudo sh install.sh
reboot
don’t install perl. the script does that for you.
no need to reboot either unless it asks you.
so I should leave sudo yum -y install perl
and it will be fine?
the script will install perl, I’ve never install perl.
P.S. You do know that installs a older version of VM?
Centos 7 will not be supported in the future, so Rocky 8 would be a better OS using the Beta script.
I am facing this problem
Ok, sounds like the repo may not have the version 6 anymore, maybe. I haven’t used that script for a while.
Try the new beta version at virtualmin-install/virtualmin-install.sh at master · virtualmin/virtualmin-install · GitHub
That installs version 7
P.S. I’ll just do a quick centos 7 install and test.
I appreciate you. I am not very technical.
Can I get the script like the above I shared
like this
sudo yum -y update
sudo sh install.sh
wget https://raw.githubusercontent.com/virtualmin/virtualmin-install/master/virtualmin-install.sh
I had same issue using the old script.
can you write that script in the short form as I shared
like this
sudo yum -y update
sudo sh install.sh
because I am not very technical, I am not aware of its commands. Please if you can.
Not sure what you mean, you can right click on the link and use copy link then paste into your shell, I have not short form.
sh virtualmin-install.sh
If your using the script on the old install use it with the -s flag, to fix the repo locations only.
Thank you very much. I am trying
This should be fixed now.
Run yum clean all and try again.
Hi Joe, you mean below script will work now?
yum -y update
yum -y install perl
yum install wget
wget https://software.virtualmin.com/gpl/scripts/virtualmin-install.sh
reboot
You only need 3 lines.
yum clean all
sudo is not needed in front of the line if your a root user.
Steve
There is no reason to use the beta installer on CentOS 7.
But, also, no one should be installing a new system on CentOS 7 today. It is already several years old.
I fired up Centos 7 to see if there was a issue and ran the default install script and it fails. Totally clean install on Vultr. I thought maybe the repos may have changed and missing VM6 or something in there.
Gotta go to work now I can try again later but I can’t see running yum clean all would make a difference is if it is clean when I first ran the script.
Steve
@stefan1959 thank you very much. its working for me :slight_smile:
No prob, but like Joe said, centos 7 is getting old. Rocky 8 or even 9 maybe is a better option. They a Centos almost clone. https://rockylinux.org/
