Hi guys,
I already installed virtualmin many times without any problem.
But now, I have a problem during the installation.
Server: Centos 5.5 x86_64
Error message:
INFO - /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix bind spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-domxl php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay: Succeeded.
INFO - Succeeded.
INFO - Installing Virtualmin and all related packages now using the command:
INFO - yum clean all
Loaded plugins: fastestmirror
Cleaning up Everything
Cleaning up list of fastest mirrors
INFO - yum -y -d 2 install virtualmin-base
…in progress, please wait… |http://software.virtualmin.com/gpl/universal/wbm-virtual-server-3.84.gpl-1.noarch.rpm: [Errno 4] IOError: <urlopen error (104, ‘Connection reset by peer’)>
Trying other mirror. /http://software.virtualmin.com/gpl/universal/wbt-virtual-server-theme-8.0-1.noarch.rpm: [Errno 4] IOError: <urlopen error (104, ‘Connection reset by peer’)>
Trying other mirror. \http://software.virtualmin.com/gpl/universal/ust-virtual-server-theme-6.9-1.noarch.rpm: [Errno 4] IOError: <urlopen error (104, ‘Connection reset by peer’)>
Trying other mirror. |http://software.virtualmin.com/gpl/rhel/5/x86_64/proftpd-1.3.3c-1.el5.vm.x86_64.rpm: [Errno 4] IOError: <urlopen error (104, ‘Connection reset by peer’)>
Trying other mirror. -http://software.virtualmin.com/gpl/rhel/5/x86_64/clamav-lib-0.96.5-1.vm.el5.x86_64.rpm: [Errno 4] IOError: <urlopen error (104, ‘Connection reset by peer’)>
Trying other mirror. |http://software.virtualmin.com/gpl/universal/usermin-1.460-1.noarch.rpm: [Errno 4] IOError: <urlopen error (104, ‘Connection reset by peer’)>
Trying other mirror. /http://software.virtualmin.com/gpl/universal/webmin-1.540-1.noarch.rpm: [Errno 4] IOError: <urlopen error (104, ‘Connection reset by peer’)>
Trying other mirror. |http://software.virtualmin.com/gpl/rhel/5/x86_64/clamav-data-0.96.5-1.vm.el5.x86_64.rpm: [Errno 4] IOError: <urlopen error (104, ‘Connection reset by peer’)>
Error Downloading Packages:
2:wbt-virtual-server-theme-8.0-1.noarch: failure: wbt-virtual-server-theme-8.0-1.noarch.rpm from virtualmin-universal: [Errno 256] No more mirrors to try.
clamav-data-0.96.5-1.vm.el5.x86_64: failure: clamav-data-0.96.5-1.vm.el5.x86_64.rpm from virtualmin: [Errno 256] No more mirrors to try.
clamav-lib-0.96.5-1.vm.el5.x86_64: failure: clamav-lib-0.96.5-1.vm.el5.x86_64.rpm from virtualmin: [Errno 256] No more mirrors to try.
2:ust-virtual-server-theme-6.9-1.noarch: failure: ust-virtual-server-theme-6.9-1.noarch.rpm from virtualmin-universal: [Errno 256] No more mirrors to try.
proftpd-1.3.3c-1.el5.vm.x86_64: failure: proftpd-1.3.3c-1.el5.vm.x86_64.rpm from virtualmin: [Errno 256] No more mirrors to try.
webmin-1.540-1.noarch: failure: webmin-1.540-1.noarch.rpm from virtualmin-universal: [Errno 256] No more mirrors to try.
wbm-virtual-server-3.84.gpl-1.noarch: failure: wbm-virtual-server-3.84.gpl-1.noarch.rpm from virtualmin-universal: [Errno 256] No more mirrors to try.
usermin-1.460-1.noarch: failure: usermin-1.460-1.noarch.rpm from virtualmin-universal: [Errno 256] No more mirrors to try.
yum -y -d 2 install virtualmin-base failed. Error (if any): 0
Displaying the last 15 lines of /root/virtualmin-install.log to help troubleshoot this problem:
wbm-virtualmin-init noarch 2:2.1-1 virtualmin-universal 23 k
wbm-virtualmin-mailman noarch 2:6.0-1 virtualmin-universal 42 k
wbm-virtualmin-registrar noarch 2:2.0-1 virtualmin-universal 58 k
wbm-virtualmin-svn noarch 2:4.8-1 virtualmin-universal 44 k
wbt-virtual-server-mobile noarch 2:2.4-1 virtualmin-universal 71 k
wbt-virtual-server-theme noarch 2:8.0-1 virtualmin-universal 2.2 M
webmin noarch 1.540-1 virtualmin-universal 16 M
Transaction Summary
Install 35 Package(s)
Upgrade 0 Package(s)
Total download size: 64 M
FATAL - Fatal Error Occurred: Installation failed: 0
It seems that some packages cannot be downloaded from this URL: http://software.virtualmin.com/gpl/universal/
Of course, I checked my network card and my DNS: everything is fine.
My question is: why I cannot download some packages with the install.sh script?
If I dowload them manually, it fails too.
Is there any reason?
I tried since many days, same.
I have noticed that if I tried to download these packages from my server located in US, it’s ok, but from my server is China, I cannot!
So, second question: can I download manually these packages and install them myself? Then, next time, the install script should not try to download them again right?
Thank you
