hi
iam trying to install virtualmin on cento6 unfortunately installation fails. i enabled epel repo and this my error log
INFO - 2015-07-27 01:38:47 - Started installation log in /root/virtualmin-install.log
DEBUG - 2015-07-27 01:38:47 - Install mode: full
DEBUG - 2015-07-27 01:38:47 - Product: Virtualmin GPL
DEBUG - 2015-07-27 01:38:47 - Virtualmin Meta-Package list: virtualmin-base
DEBUG - 2015-07-27 01:38:47 - install.sh version: 1.1.2
INFO - 2015-07-27 01:38:47 - Checking for fully qualified hostname…
INFO - 2015-07-27 01:38:47 - Hostname OK: fully qualified as test.xyz.com
INFO - 2015-07-27 01:38:47 - Installing serial number and license key into /etc/virtualmin-license
INFO - 2015-07-27 01:38:47 - Loading OS selection library…
INFO - 2015-07-27 01:38:48 - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - 2015-07-27 01:38:48 - Loading OS list…
INFO - 2015-07-27 01:38:48 - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - 2015-07-27 01:38:48 - Operating system name: Red Hat Enterprise Linux
INFO - 2015-07-27 01:38:48 - Operating system version: 6
INFO - 2015-07-27 01:38:48 - Configuring package manager for Red Hat Enterprise Linux 6…
INFO - 2015-07-27 01:38:48 - Disabling SELinux during installation…
DEBUG - 2015-07-27 01:38:49 - setenforce 0 succeeded
INFO - 2015-07-27 01:38:49 - Download of http://software.virtualmin.com/gpl/rhel/6/x86_64/virtualmin-release-latest.noarch.rpm Succeeded.
INFO - 2015-07-27 01:38:57 - Succeeded.
INFO - 2015-07-27 01:38:57 - Installing dependencies using command: /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel mariadb mariadb-server postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay mlocate perl-LWP-Protocol-https
Loaded plugins: product-id, refresh-packagekit, security, subscription-manager
This system is not registered to Red Hat Subscription Management. You can use subscription-manager to register.
Setting up Install Process
Package 32:bind-utils-9.8.2-0.17.rc1.el6.x86_64 already installed and latest version
Package 2:postfix-2.6.6-2.2.el6_1.x86_64 already installed and latest version
Package 1:quota-3.17-18.el6.x86_64 already installed and latest version
Package iptables-1.4.7-9.el6.x86_64 already installed and latest version
Package openssl-1.0.0-27.el6.x86_64 already installed and latest version
Package python-2.6.6-36.el6.x86_64 already installed and latest version
No package mariadb available.
No package mariadb-server available.
No package rh-postgresql available.
No package rh-postgresql-server available.
Package logrotate-3.7.8-16.el6.x86_64 already installed and latest version
No package php-imap available.
No package php-snmp available.
No package php-mbstring available.
Package cyrus-sasl-2.1.23-13.el6_3.1.x86_64 already installed and latest version
Package cyrus-sasl-gssapi-2.1.23-13.el6_3.1.x86_64 already installed and latest version
No package rubygems available.
No package perl-XML-Simple available.
Package perl-Crypt-SSLeay-0.57-16.el6.x86_64 already installed and latest version
Package mlocate-0.22.2-4.el6.x86_64 already installed and latest version
No package perl-LWP-Protocol-https available.
Resolving Dependencies
–> Running transaction check
—> Package bind.x86_64 32:9.8.2-0.17.rc1.el6 will be installed
—> Package dovecot.x86_64 1:2.0.9-5.el6 will be installed
—> Package httpd.x86_64 0:2.2.15-26.el6 will be updated
—> Package httpd.x86_64 1:2.2.15-39.el6.vm will be an update
–> Processing Dependency: httpd-tools = 1:2.2.15-39.el6.vm for package: 1:httpd-2.2.15-39.el6.vm.x86_64
—> Package mailman.x86_64 3:2.1.12-18.el6 will be installed
—> Package mod_dav_svn.x86_64 0:1.6.11-7.el6 will be installed
—> Package mod_perl.x86_64 0:2.0.4-10.el6 will be installed
–> Processing Dependency: perl(BSD::Resource) for package: mod_perl-2.0.4-10.el6.x86_64
—> Package mod_python.x86_64 0:3.3.1-16.el6 will be installed
—> Package mod_ssl.x86_64 2:2.2.15-39.el6.vm will be installed
–> Processing Dependency: libcrypto.so.10(libcrypto.so.10)(64bit) for package: 2:mod_ssl-2.2.15-39.el6.vm.x86_64
–> Processing Dependency: libcrypto.so.10(OPENSSL_1.0.1)(64bit) for package: 2:mod_ssl-2.2.15-39.el6.vm.x86_64
–> Processing Dependency: libssl.so.10(libssl.so.10)(64bit) for package: 2:mod_ssl-2.2.15-39.el6.vm.x86_64
–> Processing Dependency: libcrypto.so.10(OPENSSL_1.0.1_EC)(64bit) for package: 2:mod_ssl-2.2.15-39.el6.vm.x86_64
—> Package mysql.x86_64 0:5.1.66-2.el6_3 will be installed
—> Package mysql-devel.x86_64 0:5.1.66-2.el6_3 will be installed
–> Processing Dependency: openssl-devel for package: mysql-devel-5.1.66-2.el6_3.x86_64
—> Package mysql-server.x86_64 0:5.1.66-2.el6_3 will be installed
—> Package perl-DBD-MySQL.x86_64 0:4.013-3.el6 will be installed
—> Package perl-DBD-Pg.x86_64 0:2.15.1-4.el6_3 will be installed
–> Processing Dependency: libpq.so.5()(64bit) for package: perl-DBD-Pg-2.15.1-4.el6_3.x86_64
—> Package php.x86_64 0:5.3.3-22.el6 will be installed
–> Processing Dependency: php-common(x86-64) = 5.3.3-22.el6 for package: php-5.3.3-22.el6.x86_64
–> Processing Dependency: php-cli(x86-64) = 5.3.3-22.el6 for package: php-5.3.3-22.el6.x86_64
—> Package php-gd.x86_64 0:5.3.3-22.el6 will be installed
–> Processing Dependency: libXpm.so.4()(64bit) for package: php-gd-5.3.3-22.el6.x86_64
—> Package php-mysql.x86_64 0:5.3.3-22.el6 will be installed
–> Processing Dependency: php-pdo(x86-64) for package: php-mysql-5.3.3-22.el6.x86_64
—> Package php-odbc.x86_64 0:5.3.3-22.el6 will be installed
–> Processing Dependency: libodbc.so.2()(64bit) for package: php-odbc-5.3.3-22.el6.x86_64
—> Package php-pear.noarch 1:1.9.4-4.el6 will be installed
—> Package php-pgsql.x86_64 0:5.3.3-22.el6 will be installed
—> Package php-xml.x86_64 0:5.3.3-22.el6 will be installed
—> Package php-xmlrpc.x86_64 0:5.3.3-22.el6 will be installed
—> Package postgresql.x86_64 0:8.4.13-1.el6_3 will be installed
—> Package postgresql-server.x86_64 0:8.4.13-1.el6_3 will be installed
—> Package procmail.x86_64 0:3.22-25.1.el6 will be installed
—> Package ruby.x86_64 0:1.8.7.352-7.el6_2 will be installed
–> Processing Dependency: ruby-libs = 1.8.7.352-7.el6_2 for package: ruby-1.8.7.352-7.el6_2.x86_64
–> Processing Dependency: libruby.so.1.8()(64bit) for package: ruby-1.8.7.352-7.el6_2.x86_64
—> Package ruby-devel.x86_64 0:1.8.7.352-7.el6_2 will be installed
—> Package spamassassin.x86_64 0:3.3.1-2.el6 will be installed
–> Processing Dependency: perl(NetAddr::IP) >= 4.000 for package: spamassassin-3.3.1-2.el6.x86_64
–> Processing Dependency: perl(Net::DNS) for package: spamassassin-3.3.1-2.el6.x86_64
–> Processing Dependency: perl(Mail::DKIM) for package: spamassassin-3.3.1-2.el6.x86_64
–> Processing Dependency: perl(IO::Socket::SSL) for package: spamassassin-3.3.1-2.el6.x86_64
–> Processing Dependency: perl(IO::Socket::INET6) for package: spamassassin-3.3.1-2.el6.x86_64
–> Processing Dependency: perl(Encode::Detect) for package: spamassassin-3.3.1-2.el6.x86_64
—> Package subversion.x86_64 0:1.6.11-7.el6 will be installed
—> Package webalizer.x86_64 0:2.21_02-3.3.el6 will be installed
–> Processing Dependency: libgd.so.2()(64bit) for package: webalizer-2.21_02-3.3.el6.x86_64
—> Package gd.x86_64 0:2.0.35-11.el6 will be installed
—> Package httpd-tools.x86_64 0:2.2.15-26.el6 will be updated
—> Package httpd-tools.x86_64 1:2.2.15-39.el6.vm will be an update
–> Processing Dependency: libcrypto.so.10(libcrypto.so.10)(64bit) for package: 1:httpd-tools-2.2.15-39.el6.vm.x86_64
–> Processing Dependency: libssl.so.10(libssl.so.10)(64bit) for package: 1:httpd-tools-2.2.15-39.el6.vm.x86_64
—> Package libXpm.x86_64 0:3.5.10-2.el6 will be installed
—> Package openssl-devel.x86_64 0:1.0.0-27.el6 will be installed
–> Processing Dependency: zlib-devel for package: openssl-devel-1.0.0-27.el6.x86_64
–> Processing Dependency: krb5-devel for package: openssl-devel-1.0.0-27.el6.x86_64
—> Package perl-BSD-Resource.x86_64 0:1.29.03-3.el6 will be installed
—> Package perl-Encode-Detect.x86_64 0:1.01-2.el6 will be installed
—> Package perl-IO-Socket-INET6.noarch 0:2.56-4.el6 will be installed
–> Processing Dependency: perl(Socket6) for package: perl-IO-Socket-INET6-2.56-4.el6.noarch
—> Package perl-IO-Socket-SSL.noarch 0:1.31-2.el6 will be installed
–> Processing Dependency: perl(Net::SSLeay) >= 1.21 for package: perl-IO-Socket-SSL-1.31-2.el6.noarch
–> Processing Dependency: perl(Net::LibIDN) for package: perl-IO-Socket-SSL-1.31-2.el6.noarch
—> Package perl-Mail-DKIM.noarch 0:0.37-2.el6 will be installed
–> Processing Dependency: perl(Mail::Address) for package: perl-Mail-DKIM-0.37-2.el6.noarch
–> Processing Dependency: perl(Crypt::OpenSSL::RSA) for package: perl-Mail-DKIM-0.37-2.el6.noarch
—> Package perl-Net-DNS.x86_64 0:0.65-4.el6 will be installed
–> Processing Dependency: perl(Digest::HMAC_MD5) for package: perl-Net-DNS-0.65-4.el6.x86_64
—> Package perl-NetAddr-IP.x86_64 0:4.027-7.el6 will be installed
—> Package php-cli.x86_64 0:5.3.3-22.el6 will be installed
—> Package php-common.x86_64 0:5.3.3-22.el6 will be installed
—> Package php-pdo.x86_64 0:5.3.3-22.el6 will be installed
—> Package postgresql-libs.x86_64 0:8.4.13-1.el6_3 will be installed
—> Package ruby-libs.x86_64 0:1.8.7.352-7.el6_2 will be installed
–> Processing Dependency: libreadline.so.5()(64bit) for package: ruby-libs-1.8.7.352-7.el6_2.x86_64
—> Package unixODBC.x86_64 0:2.2.14-12.el6_3 will be installed
—> Package compat-readline5.x86_64 0:5.2-17.1.el6 will be installed
—> Package krb5-devel.x86_64 0:1.10.3-10.el6 will be installed
–> Processing Dependency: libselinux-devel for package: krb5-devel-1.10.3-10.el6.x86_64
–> Processing Dependency: libcom_err-devel for package: krb5-devel-1.10.3-10.el6.x86_64
–> Processing Dependency: keyutils-libs-devel for package: krb5-devel-1.10.3-10.el6.x86_64
—> Package perl-Crypt-OpenSSL-RSA.x86_64 0:0.25-10.1.el6 will be installed
–> Processing Dependency: perl(Crypt::OpenSSL::Random) for package: perl-Crypt-OpenSSL-RSA-0.25-10.1.el6.x86_64
–> Processing Dependency: perl(Crypt::OpenSSL::Bignum) for package: perl-Crypt-OpenSSL-RSA-0.25-10.1.el6.x86_64
—> Package perl-Digest-HMAC.noarch 0:1.01-22.el6 will be installed
–> Processing Dependency: perl(Digest::SHA1) for package: perl-Digest-HMAC-1.01-22.el6.noarch
—> Package perl-MailTools.noarch 0:2.04-4.el6 will be installed
–> Processing Dependency: perl(Date::Parse) for package: perl-MailTools-2.04-4.el6.noarch
–> Processing Dependency: perl(Date::Format) for package: perl-MailTools-2.04-4.el6.noarch
—> Package perl-Net-LibIDN.x86_64 0:0.12-3.el6 will be installed
—> Package perl-Net-SSLeay.x86_64 0:1.35-9.el6 will be installed
—> Package perl-Socket6.x86_64 0:0.23-3.el6 will be installed
—> Package zlib-devel.x86_64 0:1.2.3-29.el6 will be installed
—> Package keyutils-libs-devel.x86_64 0:1.4-4.el6 will be installed
—> Package libcom_err-devel.x86_64 0:1.41.12-14.el6 will be installed
—> Package libselinux-devel.x86_64 0:2.0.94-5.3.el6 will be installed
–> Processing Dependency: libsepol-devel >= 2.0.32-1 for package: libselinux-devel-2.0.94-5.3.el6.x86_64
–> Processing Dependency: pkgconfig(libsepol) for package: libselinux-devel-2.0.94-5.3.el6.x86_64
—> Package perl-Crypt-OpenSSL-Bignum.x86_64 0:0.04-8.1.el6 will be installed
—> Package perl-Crypt-OpenSSL-Random.x86_64 0:0.04-9.1.el6 will be installed
—> Package perl-Digest-SHA1.x86_64 0:2.12-2.el6 will be installed
—> Package perl-TimeDate.noarch 1:1.16-11.1.el6 will be installed
—> Package libsepol-devel.x86_64 0:2.0.41-4.el6 will be installed
–> Finished Dependency Resolution
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
FATAL - 2015-07-27 01:39:07 - Fatal Error Occurred: Something went wrong during installation: 0
FATAL - 2015-07-27 01:39:07 - Cannot continue installation.
FATAL - 2015-07-27 01:39:07 - Attempting to remove virtualmin repository configuration, so the installation can be
FATAL - 2015-07-27 01:39:07 - re-attempted after any problems have been resolved.
FATAL - 2015-07-27 01:39:07 - Removing temporary directory and files.
FATAL - 2015-07-27 01:39:07 - If you are unsure of what went wrong, you may wish to review the log
FATAL - 2015-07-27 01:39:07 - in /root/virtualmin-install.log
