Dear All,
I’m trying to install virtualmin on a fresh CentOS 5 distro via the install script. The installation failed, when checking the log files here is where it fails :
Starting saslauthd: saslauthd[23617] :detach_tty : Cannot start saslauthd
saslauthd[23617] :detach_tty : Another instance of saslauthd is currently running
[FAILED]
Configuring Virtualmin
Configuring Procmail
Configuring Webalizer
Updating /etc/shells
Enabling MySQL and PostgreSQL
Enabling Apache
Configuring and enabling BIND
Configuring resolv.conf to use local DNS server
Configuring and enabling Mailman
List creation error : List creation command failed :
Enabling status monitoring
Error occurred while enabling status monitoring: An error was detected in the new Cron configuration :
0,5,10,15,20,25,30,35,40,45,50,55 * * * * /etc/webmin/status/monitor.plat …/web-lib-funcs.pl line 1360.
Hiding the Webmin upgrade page
Error occurred hiding Webmin upgrade page:
Configuring firewall rules
Allowing traffic on TCP port: ssh
Allowing traffic on TCP port: smtp
Allowing traffic on TCP port: domain
Allowing traffic on TCP port: ftp
Allowing traffic on TCP port: ftp-data
Allowing traffic on TCP port: pop3
Allowing traffic on TCP port: pop3s
Allowing traffic on TCP port: imap
Allowing traffic on TCP port: imaps
Allowing traffic on TCP port: http
Allowing traffic on TCP port: https
Allowing traffic on TCP port: 10000
Allowing traffic on TCP port: 20000
Allowing traffic on UDP port: domain
Allowing traffic on UDP port: ftp
Allowing traffic on UDP port: ftp-data
Re-checking supported Webmin modules
error: %post(virtualmin-base-1.0-61.rh.noarch) scriptlet failed, exit status 255
Any idea of what’s wrong ?
Thanks,
Mathieu
