| SYSTEM INFORMATION | |
| OS type and version | Ubuntu Linux 20.04.6 |
| Webmin version | 2.021 |
| Usermin version | 1.861 |
| Virtualmin version | 7.7 |
| Theme version | 20.21 |
| Package updates | All installed packages are up to date |
I have a custom command which installs nvm in a user-context:
During install-process, it add some entries to bashrc to make it work as expecting.
This is added at the end of .bashrc
export NVM_DIR="$HOME/.nvm"
[ -s "$NVM_DIR/nvm.sh" ] && \. "$NVM_DIR/nvm.sh" # This loads nvm
[ -s "$NVM_DIR/bash_completion" ] && \. "$NVM_DIR/bash_completion" # This loads nvm bash_completion
If I login as user, and do node --version I see my choosed Version 18.15.0.
But if I do execute same command node --version via custom commands, I see another node-version (10.x) which is not from nvm.
So I’ve added the command env to custom commands and found, that there are no path to nvm-node are added.
I tried with the same user in both cases. Means on CLI & via Virtualmin (switch into VM-Server Admin as user)
QUESTIONS:
- How to make the
custom commandsenvironment variables equal to thebash-ones? - Why does
custom commandsdon’t have the same env-vars / values as bashrc has? (in wich context does the user run here?)
BTW: I’ve tried to create and use ‘Virtuamin → System Customization → Global Variables’ for custom-commands, but don’t get it to work. Any suggestion how to use this?
