I am runnig centos 5.5 final x86_64 OS. I am trying to install virtualmin GPL on my system but everytime getting error. after looking in to the log it seems there is not error in log file. this is what i am getting everytime…
Welcome to the Virtualmin GPL installer, version 1.0.4
WARNING:
The installation is quite stable and functional when run on a freshly
installed supported Operating System, but upgrades from existing .wbm-
based systems, or systems that already have Apache VirtualHost
directives or mail users, will very likely run into numerous problems.
Please read the Virtualmin Administrators Guide before proceeding if
your system is not a freshly installed and supported OS.
This script is not intended to update your system! It should only be
used to install Virtualmin, on a supported OS. If you have previously
installed Virtualmin via this script or the GPL version of this script,
upgrades and updates should be handled within Virtualmin itself. Once
Virtualmin is installed, you never need to run this script again.
The systems currently supported by install.sh are:
CentOS 4 and 5 on i386 and x86_64
Debian 4.0 and 5.0 on i386 and amd64
Ubuntu 8.04 LTS and 10.04 LTS on i386 and amd64
If your OS is not listed above, this script will fail. More details
about the systems supported by the script can be found here:
http://www.virtualmin.com/os-support.html
Continue? (y/n) y
Checking for HTTP client…found /usr/bin/curl -s -O
Checking for perl…found /usr/bin/perl
Loading log4sh logging library…
INFO - Started installation log in /root/virtualmin-install.log
INFO - Checking for fully qualified hostname…
INFO - Hostname OK: fully qualified as server109-228-11-66.live-servers.net
INFO - Installing serial number and license key into /etc/virtualmin-license
INFO - Loading OS selection library…
INFO - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - Loading OS list…
INFO - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - Operating system name: CentOS Linux
INFO - Operating system version: 5
INFO - Configuring package manager for CentOS Linux 5…
INFO - Disabling SELinux during installation…
/usr/sbin/setenforce: SELinux is disabled
INFO - setenforce 0 failed: 1
INFO - Download of http://software.virtualmin.com/gpl/rhel/5/x86_64/virtualmin-release-latest.noarch.rpm Succeeded.
Running updatedb so locate works…this will take a little while.
Attempting to import various system RPM-GPG-KEY files…Errors may occur,
if you’ve already imported them. It is safe to ignore these errors.
INFO - Succeeded.
INFO - Installing dependencies using command: /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix bind spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-domxl php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay
…in progress, please wait… INFO - /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix bind spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-domxl php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay: Succeeded.
INFO - Succeeded.
INFO - Installing Virtualmin and all related packages now using the command:
INFO - yum clean all
Loaded plugins: fastestmirror
Cleaning up Everything
Cleaning up list of fastest mirrors
INFO - yum -y -d 2 install virtualmin-base
…in progress, please wait… -http://mirror.ukhost4u.com/centos/5.5/addons/x86_64/repodata/repomd.xml: [Errno 4] IOError: <urlopen error (-2, ‘Name or service not known’)>
Trying other mirror. /http://mirror.sov.uk.goscomb.net/centos/5.5/updates/x86_64/repodata/filelists.sqlite.bz2: [Errno 4] IOError: <urlopen error (101, ‘Network is unreachable’)>
Trying other mirror. /http://software.virtualmin.com/gpl/universal/wbm-virtualmin-init-2.1-1.noarch.rpm: [Errno 4] IOError: <urlopen error (-2, ‘Name or service not known’)>
Trying other mirror. \http://software.virtualmin.com/gpl/rhel/5/x86_64/clamav-lib-0.96.1-1.vm.el5.x86_64.rpm: [Errno 4] IOError: <urlopen error (-2, ‘Name or service not known’)>
Trying other mirror. |
Error Downloading Packages:
clamav-lib-0.96.1-1.vm.el5.x86_64: failure: clamav-lib-0.96.1-1.vm.el5.x86_64.rpm from virtualmin: [Errno 256] No more mirrors to try.
2:wbm-virtualmin-init-2.1-1.noarch: failure: wbm-virtualmin-init-2.1-1.noarch.rpm from virtualmin-universal: [Errno 256] No more mirrors to try.
yum -y -d 2 install virtualmin-base failed. Error (if any): 0
Displaying the last 15 lines of /root/virtualmin-install.log to help troubleshoot this problem:
wbm-virtualmin-init noarch 2:2.1-1 virtualmin-universal 23 k
wbm-virtualmin-mailman noarch 2:5.9-1 virtualmin-universal 42 k
wbm-virtualmin-registrar noarch 2:2.0-1 virtualmin-universal 58 k
wbm-virtualmin-svn noarch 2:4.7-1 virtualmin-universal 43 k
wbt-virtual-server-mobile noarch 2:2.3-1 virtualmin-universal 69 k
wbt-virtual-server-theme noarch 2:7.8-1 virtualmin-universal 2.2 M
webmin noarch 1.510-1 virtualmin-universal 15 M
Transaction Summary
Install 34 Package(s)
Upgrade 0 Package(s)
Total download size: 59 M
FATAL - Fatal Error Occurred: Installation failed: 0
and same thing I can see in log file. Please help me to resolve the issue.
