Hello
After installing a new Debian 9 server with a MariaDB, I noticed trouble using VirtualMin to set the database.
Every time I wanted to modify the setting the MariaDB broke. I had to use a backup.
Then I noticed that the MariaDB was no recent 10.1 and decided to upgrade to the 10.3. Il thought that this would correct the problem.
I eventually erase the MariaDB and installed the recent version. But on the VirtualMin and Webmin it became worst.
VirtualMin can recognize MariaDB but cannot connect to MariaDB anymore :
Message in VirtualMin
MySQL Database Server | MySQL version 10.3.11
MySQL is not running on your system - database list could not be retrieved.
The full MySQL error message was : DBI connect failed : Plugin ‘unix_socket’ is not loaded
And when creating a site in Weblin :
Creating MySQL database new …
… MySQL database failed! : mysql::execute_sql_logged failed : DBI connect failed : Plugin ‘unix_socket’ is not loaded at /usr/share/webmin/web-lib-funcs.pl line 1478.
I start to understand that the management of MariaDB is different to mySQL. Is there a way to adapt VirtualMin in order to use MariaDB ?
Is this better to change from MariaDB to mySQL ?
Thanks for any help
