Virtualmin does not recognize my IPv6
Virtualmin version 8.0 Pro
I cannot get virtualmin, or to recognize my additional ipv6 ip’s. They were added from my netplan, when I loaded virtualmin. In Webmin Net Config the additional ipv4 are listed as virtual interface ensp:0 ensp:1 etc… and my addtional ipv6 are listed under the primary interface and ipv4 address. ensp: 1 ipv4 and 5 ipv6 addresses. Hope that makes sense.
Then, in virtualmin, my Virtualmin Config Network has the ipv4 and ipv6 set and not default, but the main ip’s and mask for both. They are added in Virtualmin Networking under shared, as well.
However, when I go to add a second domain and virtual server it tells me that ipv6 is not enabled on the system. Though, I did go inside the webmin config file and set ip6enable = 1, and I can ping my ip addresses from within, and they are live.
When I run a reconfig virtualmin, it tells me it see outside ipv6 and it is a random ipv6 from my range, and says ipv6 is not enabled. I have had ai run me through the basics, all day. And, I have searched for any other topics. If my netcfg.yaml file had them, why did virtualmin not catch them on the install?
Thanks for any help, and do not think I am knocking virtualmin, great software, and makes all our lives easy. And, I recommend it to everyone. First time I have had any trouble. Any help with these and I would be very thankful. I have check all the basics, and been through it more then a few times.
I got it. Not sure how to close this. But, I am good.
Maybe post what the issue was, the forum is used to find out solutions to problems
I see its mark resolved.
Sorry, I thought I closed this. I got it worked it. As I’ve learned of the years, it’s something simple, that I was missing. Ubuntu server auto assigns an outside IPv6, and this caused Virtualmin to use it. Was I re did my net plan and re configured, everything is running great.
Huge Virtualmin fan, and it sure makes many hours of work, much simpler. I will leave a good Google Review.
Thanks for this handy tool, and I’ve used it on and off for over 7 years.
You can mark any comment as the solution, by clicking the checkbox at the bottom of the comment.
If you solve it yourself, you can post a brief summary of the solution and mark that as the solution.
It’s covered in the guidelines: FAQ - Virtualmin Community
