I was in the process of implementing some firewall rules today (not sure if that’s related or not, but that’s what I happened to be doing) and suddenly the Virtualmin dashboard (i.e. main landing page) will not load. I just get the progress bar swinging from side to side but nothing appears in the main content area.
The left-hand-side menu is fine, and I can access any of the system functionality through that menu, but the dashboard itself won’t load.
I restarted Webmin, and indeed rebooted the whole machine.
I checked the miniserv.error log and here is the excerpt since restart:
[08/May/2018:17:54:57 +0100] miniserv.pl started
[08/May/2018:17:54:57 +0100] Using MD5 module Digest::MD5
[08/May/2018:17:54:57 +0100] Using SHA512 module Crypt::SHA
[08/May/2018:17:54:57 +0100] Perl module Authen::PAM needed for PAM is not installed : Can't locate Authen/PAM.pm in @INC (@INC contains: /usr/libexec/webmin /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .) at (eval 18) line 1.
BEGIN failed--compilation aborted at (eval 18) line 1.
Already running
[08/May/2018:17:58:15 +0100] [aaa.aaa.aaa.aa] Document follows : This web server is running in SSL mode. Try the URL https://domain.org:10000/ instead.
[08/May/2018:17:58:34 +0100] miniserv.pl started
[08/May/2018:17:58:34 +0100] Using MD5 module Digest::MD5
[08/May/2018:17:58:34 +0100] Using SHA512 module Crypt::SHA
[08/May/2018:17:58:34 +0100] Perl module Authen::PAM needed for PAM is not installed : Can’t locate Authen/PAM.pm in @INC (@INC contains: /usr/libexec/webmin /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .) at (eval 18) line 1.
BEGIN failed–compilation aborted at (eval 18) line 1.
Already running
[08/May/2018:18:03:25 +0100] [aaa.aaa.aaa.aa] Document follows : This web server is running in SSL mode. Try the URL https://domain.org:10000/ instead.
Already running
scheduled_collect_system_info : Already running
[08/May/2018:18:08:39 +0100] [aaa.aaa.aaa.aa] Document follows : This web server is running in SSL mode. Try the URL https://domain.org:10000/ instead.
Failed to initialize SSL connection
Already running
[08/May/2018:18:13:47 +0100] [aaa.aaa.aaa.aa] Document follows : This web server is running in SSL mode. Try the URL https://domain.org:10000/ instead.
Already running
[08/May/2018:18:18:57 +0100] [aaa.aaa.aaa.aa] Document follows : This web server is running in SSL mode. Try the URL https://domain.org:10000/ instead.
Already running
[08/May/2018:18:24:04 +0100] [aaa.aaa.aaa.aa] Document follows : This web server is running in SSL mode. Try the URL https://passport.worldrugby.org:10000/ instead.
I’m guessing the clue is the “scheduled_collect_system_info : Already running” line. Can anyone help with how I can troubleshoot this?
