Virtualmin check-connectivity
indicates this should work, but it does not (for me):
virtualmin check-connectivity --domain domain.tld
Command check-connectivity.pl was not found
OS type and version Debian 13
Webmin version 2.621
Virtualmin version 8.1.0 GPL
Usermin version 2.521
virtualmin check-connectivity [–domain name]* | [–user username]*
gives me
bash: [–user: command not found
Unable to flush stdout: Broken pipe
but that is on a Debian 12 so might have been revised on 13.
Ubuntu Server:
# virtualmin check-connectivity --domain example.com
example.com
    Status: 5 errors
    Error1: dnsip : DNS resolution mismatch : example.com resolved to xxx.xxx.xxx.xxx instead of the expected xxx.xxx.xxx.xxx
    Error2: web : Website request failed : 500 Can't connect to example.com:80 (SSL connect attempt failed error:0A0000C6:SSL routines::packet length too long error:0A000139:SSL routines::record layer failure)
    Error3: ping : Failed to ping IP address : Ping of xxx.xxx.xxx.xxx did not response in 5 seconds
    Error4: ping : Failed to ping IPv6 address : Ping of xxxx:xxxx:xxxx:xxxx:xxxx:xxxx did not response in 5 seconds
    Error5: smtp : SMTP connection failed : Connection timed out
That’s weird. I don’t see that command in the repo, but it’s listed in commands index: virtualmin-gpl/commands-lib.pl at 8b092e8b61fe698acb40fe2d075d78407c00a91b · virtualmin/virtualmin-gpl · GitHub
I don’t see where it would come from…
@Steini are you on a devel version or something?
Oh! It’s only in Pro, for reasons I can’t figure. I’ll talk to Jamie and Ilia about that…probably ought to be in GPL. It certainly shouldn’t show up in the available commands on GPL if it’s not available.
Webmin version 2.610
Usermin version 2.510
Theme version 26.20
Apache version 2.4.66
Yep, it’s a Pro only feature, and I don’t know why.
We’ll either remove it from the help output and mark it as Pro-only in the docs, or we’ll move it to GPL (I prefer the latter, but Ilia and Jamie also have a say).
Maybe offtopic
I have a issue with it, it keeps reporting this
but if I testi externally via mxtools smtp is fine.
That’s unrelated to OPs question. Make a new topic. We probably need to see the actual name that has a problem, though, in order to check it from our end to see why it’s failing, so maybe make it a PM.
Yes, the connectivity check is available only as a Pro feature, as described here:
Yet, there are many other API commands listed in the documentation that are not available in the GPL version.
The right fix is to make Virtualmin GPL to be aware of those commands and show a clear message when a command isn’t available in the GPL version and only available in Pro.
I will looking into this and update this ticket with progress.
And, making this a GPL feature, however, is a separate and unrelated topic.
Alright, the issue has been resolved on both sides. When the Virtualmin helper command is called for the Virtualmin Pro API, it now displays a clear message:
root@alma9-gpl:~# virtualmin list-acme-providers
Command list-acme-providers is only available in Virtualmin Pro
Additionally, all Pro API commands are now marked on the documentation site:
that was where i tested it
on Pro it gave the same result
I also tested on a ubuntu 24 (GPL) production same again
What do you mean by “it gave the same results”?
you are useing a domain name
