Any info would be greatly appreciated.
I ran the VirtualMin Installer and it ran great…
it got about past 3/4 mark and then kicked back with an error and deleted itself.
I don’t know what would cause this.
I should have enough memory / so I don’t think that is the problem [384mb]
The only thing I can think of is:
I did run and try to configure a straight Webmin install beforehand and then ran the uninstaller etc/uninstall
Any insight as to what I need to clear or get some results to give it another go would be helpful.
Thank you so much in advance and for the awesome software.
Displaying the last 15 lines of /root/virtualmin-install.log to help troubleshoot this problem:
Installing : fedora-usermgmt-shadow-utils [23/32]
Installing : fedora-usermgmt [24/32]
Installing : clamav-filesystem [25/32]
Installing : clamav-data [26/32]
Installing : clamav-server-sysv [27/32]
Installing : clamav-lib [28/32]
Installing : clamav-server [29/32]
Installing : clamav-update [30/32]
Installing : clamav [31/32]
Installing : virtualmin-base [32/32]
error: %post(virtualmin-base-1.0-61.rh.noarch) scriptlet failed, exit status 2
FATAL - Fatal Error Occurred: Installation failed: 0
