Hello, can you please make a guide to put apache + php7.4-fpm + reverse proxy Nginx in ubuntu 20.04
The reference in this forum is very old (obsolete), for ubuntu 16.04 and does not cover combos for both ubuntu 20.04 or for use with php7.4-fpm (obviously for https, ssl 443)
RequestHeader set “X-Forwarded-Proto” expr=%{REQUEST_SCHEME}
ProxyVia On
ProxyRequests Off
ProxyAddHeaders On
ProxyPass / http://127.0.0.1:98798/
ProxyPassReverse / http://127.0.0.1:98798/
By default Apache times out connections after one minute
ProxyTimeout 86400 # 1 day
hope this settings help you . im using for apache reverse proxy
That’s too many web servers. If you want nginx performance/efficiency use nginx. If you need Apache features use Apache. Using both gives you the worst of each and the best of none.
Thanks for the reply, it gives me a little idea (in the case of apache and nginx installer but not managed by virtualmin) i.e. the question would be how to add that via virtualmin. I’m confused.
So from your point of view if that’s not a good idea, would it be better to use Varnish? And in that case, what would be the procedure to integrate it with ssl 443?
