Have installed Virtualmin gpl, but when I run the Virtualmin server and check config its states that Apache module "mod_actions" is missing and VirtualMin is not ready to be setup.
I have looked for this module in webmin modules,CPAN,software packages and perl modules but cant find any file relating to it.
I believe I’m having the same problem here. I uncommented the “LoadModule actions_module modules/mod_actions.so” line under Webmin>Servers>Apache Webserver>Global configuration>Edit Config Files, but that didn’t fix the issue. I think you’ve mentioned a couple file locations, but I can’t find them on my machine. I’m using Solaris’ Coolstack if that’s any help. The paths are similar, but displaced into the Coolstack folder.
Oop! Nevermind! I fixed it myself! I just needed to double check that everything was properly saved and refresh the configurations stuff. I still have a couple errors, but it says Apache is all set now.
